spreader pics/recommendations for BX/B?
   / spreader pics/recommendations for BX/B? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
I saw a 500lb capacity spreader at TSC and I was shocked at how big it is. I have read real good things about the Herd M96. Any others? I am going to use it for lime (probably pelletized), fertilizer and seed. In a rare situation salt.
   / spreader pics/recommendations for BX/B? #2
Here is what I have and use them on my BX's.
The Green one I use (now) for grass seed only. It's a Ferguson Overseeder. I don't use fertilizer in it any more because the fertilizer is so corrosive and wants to eat up the metal turning impeller in the bottom. I use the Red/Orange funnel shaped one on the right for lime and fertilizer. I don't fill it all the way up because it becomes pretty top heavy and my property slopes. It has an impeller that is supposed to be more resistant to corrosion but I still wash it out really good after each use.
Oops! For picture lovers I included my first Kubota Sep 2003 a BX2200. I built the pad and bought the tractor before I built my house.:)
Anyone use a 3pt spreader? Good, Bad?
   / spreader pics/recommendations for BX/B? #4
i have a spyker electric model 120 mounted on a 3 point hitch on the rear of my bx along with a 100 lb hopper extension. . it is/was a pricey proposition. i am a believer in spyker spreaders, so i followed thru with it . . . it ran about a gee wiz.
retrospectively, i wish i had looked harder at the herd 96 spreader. about half the dollars.
of note, the hopper on my spyker electric model 120 is plastic , i suspect it will still require the mandatory cleaning after each use . . . that all spreaders require. shrekbelly
I have not considered electric. Is there an advantage to that? That is alot of money for a spreader!
   / spreader pics/recommendations for BX/B? #6
I have one but have not used it - try you tube you can find videos of them in action - they fling some stuff for sure !!
I plan on using mine in the spring for seed and fert and for spreading corn next year during hunting season
UNUSED INDUSTRIAS AMERICA EASY MAN CATTLE RAMP (A57192)
UNUSED INDUSTRIAS...
BUDGIT 1 TON CHAIN HOIST (A57192)
BUDGIT 1 TON CHAIN...
HAMM HD14i SMOOTH DBL DRUM ROLLER (A52707)
HAMM HD14i SMOOTH...
2016 KOMATSU PC210LC-11 EXCAVATOR (A52707)
2016 KOMATSU...
2020 JOHN DEERE 245G LC EXCAVATOR (A52707)
2020 JOHN DEERE...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
