Spraying Concrete?
   / Spraying Concrete? #12
It gets more complicated because I can't get right up to the site to work on the steep slope. It's across a creek.... That's what got me start thinking along the lines of some kind of blob cannon that would shoot a cup-size blob of concrete or something about 50 feet. It would be a sort of long process. Need to build up a footer at the far edge of the creek first, and then rise up along the wall from there.
Once you have a footer to keep the soil from washing out from under the concrete, why not use rip rap (or bigger) stones and mortar to build a wall. That way all parts will be small enough to carry to the site, since you can't get equipment to it?
   / Spraying Concrete? #13
If I'm understanding you correctly, the root cause is periodic bank erosion. You may just want to fix that part, perhaps by using cast in place rip rap(cast concrete blocks or bars) at the stream bank edge. .
Exactly, periodic bank erosion would describe the problem exactly.That far bank is kind of vertical at the best, tends to ge undercut, and the stream is swift.
None of this is a problem on the gently sloping accessible side of the creek. The problem is the far side which as I say is near vertical and undercut.. I may just have to let it collapse. The stream isn't too big, but it is just a little too deep and swift and rocky for either of our TLBs to risk. An excavator could probably move around in the creek even with the tracks submerged....although I'm guessing about that as I don't know much about tracked machines. But even so, it couldn't do much about the bank problem by itself.
That's why I started this thread wondering about shooting some blobs of concrete across the water. A blob cannon?
rScotty
   / Spraying Concrete? #15
I think the typical rural solution to your erosion problem would be to dump 3-4 old car bodies in the creek.
Bruce
   / Spraying Concrete? #16
Save your time & energy and just let nature take its course.
The wall is undercut and will keep doing that. There are solutions but they require an engineered solution and big money.
   / Spraying Concrete? #17
Investigate 3d geocells, they can reinforce Creek and stabilize slope. Concrete would need to be keyed into Creek bed to prevent scour and then worry about pore pressure behind concrete
   / Spraying Concrete? #18
Hmmm.... well, you've all given me a lot to think about. I'll take some pictures today to post. The area I want to stabilize is too steep for rip-rap or geotextile&soil nails. The problem is that the hillside is constantly being undercut by high water flows in the creek below. At each high flow, the creek chews out another foot at the bottom, and the entire steep slope above then slides down - carrying trees and plants with it. Eventually it will stabilize of course. But it will be really ugly for 100 years if it does what I think it will do.
rScotty
Unless you have deep pockets a.k.a. you are a government employee spending our bottomless tax dollars, you are likely fighting a losing battle.
Once the water starts undermining the shotcrete it's a goner.
You could do something like a gabian wall with geotextile behind it but be prepare to spend a lot of money. It probably won't be a one man job in your situation and a lot of cost will be in the labor to install.
   / Spraying Concrete? #19
3d geogrid is fabric with pockets.it can be filled with stone or soil. It protects bank from erosion and stabilize hillside for vegetation growth. It can move if Creek erodes under it. I have seen project after it was used, good stuff
   / Spraying Concrete? #20
People have been fighting Mother Nature since the beginning of time. Mom ain't lost a round yet.
Brent 640 Gravity Wagon (A50775)
Brent 640 Gravity...
33'x25' Double Garage Steel Barn Shed (A53316)
33'x25' Double...
FAKE (A52472)
FAKE (A52472)
2011 Ford Edge AWD SUV (A55758)
2011 Ford Edge AWD...
25077 (A51694)
25077 (A51694)
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
