Sprayer
/ Sprayer #1
BluRock
Looking to build a sprayer, possibly with nozzles close to ground level. Will read postings.................BluRock
/ Sprayer #2
/ Sprayer #3
I built mine. Made a boom to bolt to the front weight bracket (two bolts) of my JD 425, JD 445, JD X485, and JD 455, that has 4 spray nozzles. Ball valves make it so one to four can be on for spraying. 30 gal tank is on a lawn-trailer chassis for easy hook-up to the drawbar, and it has a Shur-flo 12 v pump, a filter, a pressure gauge, and a return line to the tank. Added a connector into the rear tail light for power, so dash-mounted lights-on/off switch is used to turn the pump on and off. Quick and easy.
Bought parts at local tractor supply house, similar to TSC.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
AGT Industrial SSECAG-Y QA Auger W/ Bits (A60463)
AGT Industrial...
Case-IH 370 Steiger (A57148)
Case-IH 370...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
Kubota M1048A Forks (A60462)
Kubota M1048A...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
