Sprayer
/ Sprayer #1
BluRock
Looking to build a sprayer, possibly with nozzles close to ground level. Will read postings.................BluRock
/ Sprayer #2
/ Sprayer #3
I built mine. Made a boom to bolt to the front weight bracket (two bolts) of my JD 425, JD 445, JD X485, and JD 455, that has 4 spray nozzles. Ball valves make it so one to four can be on for spraying. 30 gal tank is on a lawn-trailer chassis for easy hook-up to the drawbar, and it has a Shur-flo 12 v pump, a filter, a pressure gauge, and a return line to the tank. Added a connector into the rear tail light for power, so dash-mounted lights-on/off switch is used to turn the pump on and off. Quick and easy.
Bought parts at local tractor supply house, similar to TSC.
Volvo EC220EL (A60462)
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
John Deere Gator (A60463)
John Deere Gator...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
2019 GALYEAN...
