Sprayer
   / Sprayer #1
BluRock
Looking to build a sprayer, possibly with nozzles close to ground level. Will read postings.................BluRock
   / Sprayer #2
   / Sprayer #3
I built mine. Made a boom to bolt to the front weight bracket (two bolts) of my JD 425, JD 445, JD X485, and JD 455, that has 4 spray nozzles. Ball valves make it so one to four can be on for spraying. 30 gal tank is on a lawn-trailer chassis for easy hook-up to the drawbar, and it has a Shur-flo 12 v pump, a filter, a pressure gauge, and a return line to the tank. Added a connector into the rear tail light for power, so dash-mounted lights-on/off switch is used to turn the pump on and off. Quick and easy.
Bought parts at local tractor supply house, similar to TSC.
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
2014 Kubota RTV1140 CPX (A50121)
2014 Kubota...
2018 JLG 10054 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2018 JLG 10054...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2024 John Deere 6110M (A50120)
2024 John Deere...
