sprayer question
   / sprayer question #11
rdbrumfield said:
county extension agent better get his stuff together. The label on that herbicide, is law. Him reccommending you double the strength is way beyond his relm.
I would get hold of the herbicide manufacturer and see what they sat to do.
Well he didn't exactly suggest I not follow the manufacturers instructions, he just asked if I had doubled the concentration. He also asked I had used detergent in the mix(which I did). It was very dry last year when I treated and I plan to treat under better conditions this year. They seemed to be taking over last year but they are a little better this year, so far at least.
   / sprayer question #12
mike194 said:
i have converted one to a boomless type, it seems to work good as long as there is no wind at all.
Looks just like a friend's "Weed Wagon" he made, except his garden wagon was painted dark green at the factory.
   / sprayer question #13
Berniep said:
I did that exact thing I used 4 standard nozzles on about a 7 foot boom. It is on a 25 gallon wand sprayer setup with a 2gpm pump. It used to maintain about 20 psi now it's lower, the cheap guage quit on me so I don't know exactly how low but it still gets good coverage. I think I would use a couple of those boomless sprayer nozzles instead of building a long boom if i did it again. I was worried about drift and wanted to get the boom as low as possible to the ground and still cover the area. I took many trips up and down the driveway experimenting with different nozzles and boom heights.
I want to upgrade the pump to a 3gpm pump sometime but it works rfor now.
Here are somer pictures of my setup.
I have a FIMCO 55-gallon sprayer with a three section boom, and FIMCO recommends a nozzle height of 17" - 19" above the stuff to be sprayed. They also recommend a pressure of 20 - 30 PSI. However, my sprayer uses a 6-roller pump. I mounted a tennis ball to a piece of rope and hung it to the end of each boom. It sure makes setting boom height on the fly easier.
   / sprayer question #14
Thats a pretty good idea, especially with a tractor like mine that doesn't have position control on the 3ph.
   / sprayer question #15
Thanks Berniep...the tennis ball and rope trick was one idea I had that actually worked well. My 4200 has a simple 3PH position control on the rockshaft control lever; but it doesn't work very well due to the normal slop in all the linkages.
Wind permitting I'll give the sprayer some more work tomorrow.
   / sprayer question #16
I thinik I will jiust spot spray this spring for dandelions and do the whole yard(s) this fall. Supposed to be better to control dandelions and clover in the fall anyway.
   / sprayer question #17
Ok you sprayer guys have gotten me interested in one of these things,,, that and going through 2 agri fab spreaders in 3 years!! the last one I only used twice and the gears are toast! I only spread fertilizer and lime. THe fertilizer is not a problem,,, and I see they have liquid lime, anyone use it?
   / sprayer question #18
Here is a thread I started on my sprayer on MBN a few weeks ago. Might give you some useful ideas...Stan in SW, Mi.
Machine Builders Network
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GFB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
