Sprayer Pump Winterization and Storage
/ Sprayer Pump Winterization and Storage #1
workinonit
Elite Member
Scranton, SC
JD 5090E
What does everyone do to store and/or winterize their sprayer pumps? Obviously some ammonia or cleaner needs to be used to neutralize but do you spry some type of oil in them or anti-freeze?
/ Sprayer Pump Winterization and Storage #2
I've always used RV antifreeze in my sprayer trailer and pressure washer.
One year I forgot to do it in the pressure washer. It burst. ;)
/ Sprayer Pump Winterization and Storage #3
Automotive antifreeze in my pressure washer, to prevent the corrosion that killed my first one.
No idea about flushing a sprayer first.
/ Sprayer Pump Winterization and Storage #4
Cleaning 1 gallon ammonia to 100 gallon water. Agitate let sit overnight. Run through sprayer following day then run clean water through. This is not the complete set of instructions I do.
To winterize I put several gallons of rv antifreeze in and run it through the system and leave it.
/ Sprayer Pump Winterization and Storage #5
And i remove the filter bowl and leave it on the shelf. Learned this thru broken bowl 1 year.
/ Sprayer Pump Winterization and Storage #6
I’ve used RV antifreeze, which reminds me I need to do mine.
/ Sprayer Pump Winterization and Storage #7
RV antifreeze in mine also. No corrosion problems.
/ Sprayer Pump Winterization and Storage #8
Ditto here on my pressure washer, blow it out with compressed air and fill it with RV antifreeze which, I might add, has gone up almost double what it was a year ago.
Since we can't get good gas here any more, I also drain the fuel tank and run the carb dry.
/ Sprayer Pump Winterization and Storage #9
I guess I've just been lucky so far?
I just drain mine at the end of the season and leave the input hose loose to dangle off the end of the pump housing.
Now you guys are making me paranoid. Lol.
/ Sprayer Pump Winterization and Storage #10
I do my best to drain everything and disconnect the hoses, but then I bring the actual PTO pump into the basement where it can't freeze. Pumps have gotten crazy expensive.
/ Sprayer Pump Winterization and Storage #11
I rinse and drain the system. That's all. It is stored inside a barn that rarely sees freezing temperatures
/ Sprayer Pump Winterization and Storage #12
My well water is very hard, almost have to break up the water to drink it LOL. That's another reason I blow it out and fill it with RVAF, figure it'll stop the minerals from building up when the water evaporates in the internals of the pump.
Appreciate it. Pretty much what I was planning on. Neutralizing and flushing with anti freeze.
The filter bowl removal was a good idea I had forgotten about.
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
