Spray welding
/ Spray welding #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I am trying to get some more info on this process. What repairs you can do and what you can't. I have a tractor transmission case that was poorly cast and has sand holes in it. It weeps oil. Buying the spray weld kit would be cheaper than replacing the case if it will do a perminant fix and I would have a new toy. Can you get the powders from your local welding supply. It would also be nice to hard face.
Bill
/ Spray welding #2
I dont know too much about it. We only dabbled about the theory in school. But I have never actually used one.
But it is supposed to be the best way to repair cracks in cylinder heads and engine blocks we were told. (I went to auto trade school).
Just grind out the cracks, and spray weld with the torch to fill back in. The powder is just a cast iron dust. I doubt that it would be good for hardfacing becasue cast iron is soft.
/ Spray welding #3
Many years ago, I read about a process the used and oxyacetylene torch and hopper system to direct an iron powder into the flame that was then "sprayed onto a base for buildup of shafts. Could this be what you are talking about. I dont recall the technical name they used for it though.
/ Spray welding #4
That is the one I was refering to. I am thinking that is what is is talking about:thumbsup:
/ Spray welding #5
The one I saw was used for hardfacing and shaft build up. Depending on the powder used I suppose you could spray weld just about any material.
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2022 Ford F-250 Knapheide Service Truck (A66736)
2022 Ford F-250...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
