Spool Valves
/ Spool Valves #11
I'm not trying to be argumentative but trying to keep info correct. Feel free to correct my mistakes which unfortunately I sometimes make!!!!!!!!! I've never seen the chart you listed. I suppose chart came from JD website from it's address? That chart listed 3020 @ 14 GPM & 4020 @ 18 GPM. That chart had my 4255 listed correctly @ 26.5 GPM. Very few JD's farm tractors built from '61-'93 were open center especially if one doesn't include the ones built by Yanmar. Open center hyd models that come to mind are 1010,2010 & 3 cyl model 820,830,early 2040's. After '93 my knowledge dims without my researching. I've already contacted Peter @ Tractordata so we'll see what he thinks.
/ Spool Valves #12
Peter at Tractordata emailed me back and stated 3020 build sheet shows 20 GPM but doesn't state if it's the early or late model.
/ Spool Valves #13
J-J
Could you please advise me where you located this chart you posted?
Thanks,Jimhttps://jdparts.deere.com/partsmkt/document/english/pmac/9736_fb_HydraulicPumpSelectionGuide.htm#_JOHN_DEERE
/ Spool Valves #14
Jim,
Did you say this? It will surprise me if a 3020 has 18 CPM hyd flow
Anyway, I think the list came from Yesterdays Tractor.
/ Spool Valves #15
Jim,
Yes I stated that it would surprise me if 3020 has 18 GPM after reading on Tractordata that it's larger brother(4020) only had 13 GPM. I don't have a JD 3020 or 4020 technical manual to verify and I left JD dealership in 1987. I'm an avid member of Yesterday's tractors discussion forum but I've never seen that chart.Thanks for your reply,Jim
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
1981 FRUEHAUF CRUDE OIL TRAILER (A60736)
1981 FRUEHAUF...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
