splitter video I hope
   / splitter video I hope #1
rdbrumfield
Western Washington
5300 JD 4X4
I built this about 30 yrs ago. Just rebuilt is some by putting an engine on it instead of using the pto of the tractor and rebuilding the knife.
   / splitter video I hope #3
Can you put it on youtube then a link to youtube from here?
Or photobucket will do that also
ok, did you tube thing. plumbstriaight, watch the spelling, and wood splitter, first time in you tube, hope it worked
   / splitter video I hope #7
Letsroll- Its almost scary how much we think alike. I cut down a few trees with 36" round chunks and I was going to do the exact same thing with the crane. That really works well. Is the crane electric?
We even have the same "T" design for the splitter head. Since my splitter was separate from the hydraulic power pack, I ended up just temporarily burying the I-beam so I could just roll the big logs into the throat (mine works fine but I like yours better!) You do a lot less muscling of the logs than I do.
Pretty cool
the hoist unit is a 8000 lb hyd winch. I have a 26 hp kohler turning a 27 gpm pump from northern tools.
It was not warmed up, so was a bit slow. My son came over with his cam corder, and we just did a quickie.
It really saves the back, and having the T knife keeps the block from splitting in half so you have better control with it.
I should have taken up the boom a bit so the wood would have centered over the ram area better, but we were in a hurry.
Thank you
Lets Roll for getting that up for me. first time on youtube
X for the headsup on the you tube. first attempt at using it. Not that computer savvy.
   / splitter video I hope #9
Great setup!
That one log should supply a day or two's fire.
Now I'd like to see the chainsaw that cut that cut it! :D
066 stihl with a 32inch bar, my small one lol, used to run a 2100 homelite with a 60 in bar. Most wood here now though that 66 is plenty.
   / splitter video I hope #13
Hey !
saw the video and it looks great my only thought is to bad you couldnt hook it up to a hand held modified remote with a shoulder sling it might be a bit safer for you while hooking blocks. I run a new Hiab crane with a 500' radio controled remote. With Many many years of being hands on the valves to operate, radio have spoiled me also 5500 dollars to for the remote. That idea is out but maybe the plow remote might be a thought. great job, jpm1
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
