splitter seized up today
/ splitter seized up today #1
jnmaney
The small yellow plug is the dipstick for the tank that went empty, any idea what we're looking at here ? Engine is a Tecumseh 8 horse.
/ splitter seized up today #2
Guessing by pics /words a tear down..depending how much damage cyl. walls,piston,crank...looks like a bad gasket may have cause this.
/ splitter seized up today #4
The engine is done. That is were the engine oil goes. I would go down to Harbor Freight and buy one of the imported engines to replace it. It will be the cheapest way to go.
Chris
/ splitter seized up today #5
Welcome to TBN. Yes, like stated, the engine is toast. When you put the new engine on, do yourself a favor. Get that hyd filter off the suction side and put it on the return hose between the valve and the tank.
/ splitter seized up today #6
Just curious, but how long was it between the time when you last checked the oil level and the time it seized up?
/ splitter seized up today #7
should you be running a splitter if you don't know what that is?? i think that is a very basic question if you can't answer you prolly should not be running that??? just a thought....
/ splitter seized up today #8
Chris
this is the tractor forum right?
unbolt the motor and toss it in the scrap pile, then bolt on a couple of 3pt pins screw on some hose extensions with QA fittings and run it off the tractor!
/ splitter seized up today #11
Maybe cut the guy a little slack until he comes back with more. I don't think he meant "what is the dipstick" I think he meant "what kind of" total repairs are we looking at. OP?
Jim
/ splitter seized up today #12
I would agree with cutting him a little slack. I will toss my hat into the ring of not always checking the fluids. I am better at it now.
/ splitter seized up today #13
It will need an engine replacement. Take the engine's model, type, and code number to a Tecumseh dealer and look up the price of a replacement engine and a short block. If you can remove the parts that bolt to the block and put them back on you can get by with a short block. The short block will need the head, sheet metal, flywheel, gas tank, muffler, carburetor and intake manifold, linkage, and ignition all switched over to the new short block. We used to sell a lot of those at the shop where I worked. Just to make you feel better, once, someone bought a discounted lawn mower from a department store chain. The mower had been returned as defective, and it wouldn't turn over. I took that oil plug out and oil shot out for quite a while. I removed the spark plug and it was soaked in oil, and I was able to turn over the engine at this point. A cylinder full of oil shot out the spark plug hole. I cleaned up the mess, and spun the engine over a few times to clear more oil from the ports. I put the right amount of oil in it and started it up, outside. Everything disappeared with the smoke, but it did clear up. He had a new lawn mower for a cheap price, even paying us to empty it of the excess oil.
Thanks all, I am a mechanic for a machine tool builder and this is the first engine i toasted. Always a first thought. The black cap you see to the left of the yellow plug is what we have been using to check the oil level. ( it is a dipstick also, metal like a car style ), so the yellow must be same but for a lower resevoir. But thanks for the suggestions. the one about connecting to the tractor is one i would like to do in the interim till i get new mtr bolted in.
regards, john
/ splitter seized up today #15
Surplus Center has small gas engines on sale, might be a cheap way for you to get it going. Go to their website and see if they have what you need.
/ splitter seized up today #16
regards, john
Both the black cap with the dipstick and the yellow plug go to the exact same reseviour for the oil to lubricate the engine. They are to different openeing to check the exact same level of the exact same oil. I will take a picture of the inside of a similar engine to show you.
Sellick S80 (A60462)
2025 Heavy Duty Wheel Balancer (A61568)
2025 Heavy Duty...
Sunflower Yard Art (A61569)
Sunflower Yard Art...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
(1) 27X8.50-15 TIRES W/6 LUG RIM (A62130)
(1) 27X8.50-15...
