Splitter question
/ Splitter question #1
BowlBuilder
Martinsville, IN
1985 Case/Ingersoll 448
I have a K36 splitter (love it) but don't like putting hours on my onan engine. How would this splitter perform if I were to build a separate portable hydraulic system with a standard 2 stage 11 g.p.m. splitter pump and a 5.5 horse Honda engine? Thank you in advance for any opinions on this matter.
/ Splitter question #2
It should perform quite well.
/ Splitter question #3
The K-36 has its own control valve as well as the hoses and quick couplers to connect it to the tractor's rear PTO valve. All you need is the Honda engine coupled to the hydraulic pump, a reservoir that will hold at least 6 quarts of oil, some hoses to connect the reservoir to the pump inlet and to a matching pair of quick couplers. The Honda should be more than adequate power because most owners run their CCI tractors at half throttle or less when splitting. You have the advantage of a 2 stage pump that will drop from 11 GPM down to probably 3 GPM once the pressure rises above 600 PSI or so. The Case system does not do that. However, if a Case tractor with a 9 GPM system is run at half throttle (1800 RPM), then it is only putting out 4.5 GPM during the entire splitting operation. In my opinion, Honda has a tendency to underrate the HP of their engines compared to the American engines which seem to slightly exaggerate the peak HP. Personally, I think this is a very good move on your part considering the high cost of rebuilding the Onan in your tractor. No point putting all those hours on it if you can put something like this together. The Case can then be used to haul the split wood in a wagon to wherever you need it.
/ Splitter question
Thank you very much Tom, I know I can always get the right answers from you. That is why I came to this site to ask this question. No one else on the internet is more willing to help someone out with their questions than you are. Thanks again.
2006 Ford F-350 Pickup Truck (A62613)
2006 Ford F-350...
2022 EZ-GO ELITE...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A65563)
2004 International...
