Splitter Question
/ Splitter Question #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
Is there an easy and safe way to stop a log splitter cylinder from retracting all the way. My splitter is made for 24" wood and I cut mine 14-16". I would like to save the time of the cylinder going ALL the way home.
/ Splitter Question #2
You could clamp some cylinder stops onto the cylinder rod to effectively shorten the cylinders stroke.
/ Splitter Question #3
There are spacers that look like collars. These go on the cylinder rod and are used to keep the cylinder from fully retracting. This method would do what you are trying to accomplish.
/ Splitter Question #4
You should also be able to clamp something on the beam to limit travel since it does not take that much to trip the return detent on the valve.
Landhonor Quick Attach Rolling Packer (A66408)
Landhonor Quick...
Aluminum Mermaid (A65583)
Aluminum Mermaid...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
New/Unused Pallet of Chains, Binders, and Chain Slings (A65583)
New/Unused Pallet...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
