splitter control valve...
/ splitter control valve... #21
Not clear. If you have 10 GPM flowing through the neutral port, there are no restrictions, and when you activate the valve to the extend position the neutral port is blocked and all the fluid goes to the work ports. Starting from neutral again, push the lever just a little. Now some of the flow from the neutral position, is going to the work ports, and the cylinder starts to move, and continue to move as long as you hold the lever until the relief goes off. By feathering the valve, you are only using a small amount of the fluid for the cyl, and the remaining fluid goes back to tank, or beyond. You are going to build up pressure with what ever fluid is going to the cylinders. If this valve had a PB in the circuit, and being utilized, if you were to put a flow meter in the PB line, and activate the cylinder, with a ten gal pump, how much fluid would flow through all circuits if you were feathering. and how much would flow at half lever, and how much would flow at full lever? It doesn't take much pressure or volume to operate a hyd cyl, with no load. Why does the cyl move slow when feathering? Because you are only using a small amount of fluid out of the ten gal available. That is just the way I see it.
Now, don't get all happy and saturate me with copies out of book, etc.
/ splitter control valve... #22
JJ,
Maybe I can explain it in a simpler way. Take a 3/4" garden hose connected to a faucet and nothing on the other end (simulates return to tank). Use a nail to put a hole in the hose (simulates work port). Turn on the faucet at a trickle (simulates large valve with small flow). Now begin pinching the hose near the end (simulates actuating the OC valve. How much will you have to pinch off the hose before you begin spraying water from the nail hole in the hose? Try this with the faucet all the way on (simulates mached flow and valve). The water will begin spraying through the nail hole much sooner (less valve actuation to generate power to the work port).
Clear as mud?
Amazingly simple description ....:D
/ splitter control valve... #23
Agreed.
Only if the port back to the tank or PB creates restriction to the flow. Fluid will take the path of least resistance. Even though the work port is opening, the OC port must create resistance to build pressure to the work port. In our hypithetical 10GPM system, until the OC port is closed enough to restrict the flow below 10GPM no fluid will be diverted.
Place a pressure gage before the valve. You will see that pressure is inversely proportional to valve movement. I agree that it doesn't take much pressure to operate with no load, but it does take some. Until the OC port is restricted, there is no pressure beyond restrictions created by the hoses and valves.
Back to my analogy of the garden hose...
The work port (nail hole) is fully open and unrestricted. With the faucet turned on to a trickle (no restriction created by the hose), you will be lucky to get drips out of the hole. As you begin to pinch off the hose and create restriction to the water flowing out the end, water will begin to be divirted out the nail hole. The greater the restriction, the greater the flow and greater the pressure. This is a simulation of an oversized valve.
On a properly designed system, I agree with your thoughts. With a 10GPM pump and valve, if you begin feathering the valve, the flow is immeadiately restricted and fluid begins to be divirted.
Find an old garden hose and play with different flows and watch the result. Bring the grandkids over and you might even find a way to make it fun as well.
/ splitter control valve... #24
Understand all that, but if you block off half of the neutral port, say 5 gal flow, where is the other five gal going? Now you have a restriction, and some pressure will start to build up, and the work port is open somewhat. Now, say you block off 7 GPM, and 3 GPM flowing on down stream, then the cyl will operate faster. As you finally block off the flow downstream, all the pump volume is going to the work ports, until the pressure is relieved.
How else can a feather situation work?
/ splitter control valve... #25
You are absolutely correct. I think it was the discussion of a 25GPM valve on the 10GPM flow where we were having confusion. I was trying to help explain why there would be no feather control (or control period) until he got past half way on the valve. Once the valve restricted flow to less than 10GPM through the OC (neutral) port, function is exactly as you describe.
So, as I understand it so far, I'm holding the (20gpm valve with only 10gpm total available) at a halfway point, the cylinder starts to move. As I would expect it to. Now it comes to bear on the log to be split. Still holding the lever at the halfway point, I would expect it to cease movement at a point convenient for the control valve to prefer returning fluid to the tank. It seems to me it's not able to build much pressure because of the 'leak', if you will, to the tank. The closer I move the valve to shut the flow to the tank (consequently making more pressure/volume available to the cylinder side) the more the cylinder will be able to move. Sounds almost like a balancing act of controlling the pressure (and volume) between the tank and the cylinder. Am I on the right track in understanding?
/ splitter control valve... #27
You seem understand to the general idea. On an OC/CF system, is the restriction of flow through the neutral port which creates pressure. The neutral and work ports open and close opposite of each other. As the neutral port is closed, the work port is opened and vice-verse.
To move any cylinder, sufficient pressure must be created to overcome the resistance on the cylinder.
Added:
On our hypothetical 10GPM log splitter system, it the output on the neutral port is restricted to , say 9GPM, pressure will build until something changes. That could be the log splitting, RV opening, change in valve position, etc...
/ splitter control valve... #28
My logsplitter valve is rated for 25 gpm, but my tractor can't produce much more than 7 or 8 gpm to the remote valves. If you had a hydraulic motor rated at 25 gpm, much lower flow would not produce satisfactory results. On a log splitter, it doesn't matter about the valve. The size of the cyliinder will determine your cycle times for a given flow rate.
Your log splitter valve is about 3 times the volume from your tractor. Do you notice any difference as to lever movement, say from your tractor. Do you have feather control from the git go?
I think that is what [ mrcaptainbob ] wants to know. My view, is that you will not have the fine control as with a matched up valve/pump. It should work if the pressure and port requirements are met.
Sorry for any confusion.
/ splitter control valve... #29
You guys are really discussing this in a great way now.....But I want to add something that still sounds to be little diffuse.
A fixed displacement pump at a given rpm, will always deliver its rated flow thru a control valve or any other orifice, restricted or not, all the way to tank or the cylinder(s).
There is a few exceptions:
  • Internal leak in pump, RV, control valve, etc.
  • External leak
  • Any by-pass in RV or flow split in other valves
Edit:
  • And of course, not to forget, if suction line restricts
So saying a 10 GPM flow will be reduced to 9 GPM because of a restriction, will allways mean that one or more of the listed points above is the reason for the loss of 1 GPM.
What happens in a restriction is that flow in and out will be the same, but the fluid velocity at a certain cross section will be different if the cross section area is different. Velocity will be proportional to the cross area.
See Bernoulli
Fluid velocity is proportional to created pressure by a restriction. If you look at a Nomogram for hoze size recommendations, fluid velocity and flow is the inut parameters.
/ splitter control valve... #30
  • External leak
See Bernoulli
Thank you.
I don't think I stated it, and probably should have, but my statement for the neutral position being restricted to 9GPM was intended to indicate that 1GPM was diverted to the work port, or another path, for the total of 10GPM. This was a good point to bring up though, as the pump will continously deliver it's proper volume assuming there is no failure/leakage and if the work port cannot accept the fluid, the velocity of flow through the restriction will increase to maintain the 10GPM flow until relief is found. Now I'm starting to get deeper into it than I really wanted to for basic theory of valve function though.
/ splitter control valve... #31
You know, I just don't think that I pay that close of attention. I bump the valve lever until the ram seats the log firmly up to the wedge, and then I push the lever all the way to the stop while the log is splitting. If I need to stop, I immediately center the valve. What I have noticed is an amazing difference in the speed of the splitter's ram if I run the tractor at 1200-1500 rpm instead of 2000 or higher. 2000 rpm seems to be an optimum and acceptable speed for the tractor.:)
/ splitter control valve... #32
What I was try to determine, was, since you have an over-sized valve, do you have to push the lever half way before the cylinder starts to move. That is interesting about the rpm thingy. You should be pumping more GPM the more rpm you have. What I computed is this. Using a reference pump displacement of 1.2 cu in, at 2000 rpm, pump volume is 10 GPM, and at 1500 rpm, the pump volume should be 8 GPM. If you get a chance, check out that lever position for me. Thanks
/ splitter control valve... #33
Not that its the same tractor as others but on my 3 point splitter I find 1300rpm or so is the best speed to split at. Any higher rpm does not seem to yield more power and just makes more noise.
Chris
/ splitter control valve... #34
I order to have control the control element has to have the largest pressure drop of all parts of the loop. If the valve is oversized it is the pump that is the bottleneck for great part of the valve stoke. The valve will start having effect only after it is, just guessing, way past the half stroke. In other words fine control with oversized valve will be difficult. Since the application of OP is a splitter I think it would matter very little. How much of precise control a splitter needs?
/ splitter control valve... #35
Here is a practical view of what I think JJ is conveying.
I have a 5hp splitter, 4" cylinder, and a standard Prince 25 GPM log splitter detent valve. Oh, the missing element, an 11gpm pump.
So my control valve is more than double rated on total GPMs available.
I've used this same splitter for maybe 20 years? That's anywhere from 2 to 4 cords per year, for 20 years. Let's just say I am quite familiar with this set-up.
Here is how it works: When I crack the control valve to start the cylinder extension, as soon as the spool is far enough to allow flow, the cylinder moves at what appears to be it's full speed of motion. Maybe it's 80% or 90% of it's speed? But there is little to no speed control. It's like it's ON or OFF.
I have had numerous cases where I wanted to feather or move the cylinder slowly, "inch it" if you will. With the motor at operating RPMs this is nearly impossible. I can move it incrementally with a very fast quick flip of the control lever, in short bursts, to try to approximate where I want the cylinder to extend to. I CANNOT slightly open it [feather] and have it move at, let's say 25% of it's normal speed for example, it doesn't happen.
The ONLY way I can change the speed at which the cylinder moves, is by drastically reducing engine RPMs, which simply slows down ALL cylinder motion. Interestingly enough, even by cutting the pump flow this drastically, there is still NO feather control. It's like it's ON or OFF, just slower.
This would be indicative of what JJ is saying, that is, a much larger rated Control Valve, with it's larger orifices and ports, is going to "OPEN UP" to the smaller flow much more quickly.
No theories, no drawings, no diagrams. Just a practical real world offering of what happens.
Again,
As soon as I crack the valve, I have made an opening large enough to allow a large % of the flow to go to the work port , hence, the characteristic it exhibits is like being either Full ON or OFF in terms of the flow.
Hypothetical: if I replaced my pump with a 16gpm pump, I would suspect I would gain a a measured amount in the way of "control" or ability to "feather". If I upped it again, to a 22GPM pump, I would gain even more control and ability to slow the movement of the cylinder based on the control I have over the total flow.
Perhaps if my control handle on my existing set up where 3 feet long, I would be able to actuate the valve so slightly as to control the speed??
But, that's not allowed, because I started this post as a "practical" exercise.
/ splitter control valve... #36
Again,
I think this valve have a spool that closes the center EARLY, already after a short movement of the spool, and that forces the full flow to the cylinder even if port is not fully open. If we think about log splitter operation, cylinders are usually so slow so feathering is rarely necessary. Feathering allways creates flow and power losses into HEAT, so I would say a good logsplitter valve should be more on-off than not. My picture shows how a Prince valve closes center before half spools stroke......
This is one of the parameters (how spool lands over lap center and work port) valve designers are playing with to make a spool valve act a certain way, with out changing the size of the whole valve....
Edit:
Feathering or fine metering ability imrpoves a lot from those metering notches you can see on the picture. Also to mention that fine metering depends on load pressure at work port.
/ splitter control valve... #37
I agree with you 100% AKKAMAAN. I'm also certain you have a large number of students you have taught over the years that have done very well in the Fluid Power industry.
/ splitter control valve... #39
Why do the call it a "spool"?
Generally a spool is a storage device of some sort, like a spool of thread.
P.S. This discussion is very informative.
/ splitter control valve... #40
Why do you drive on the Parkway and park in the Driveway?:confused:
Why is it a "pair" of underwear?:confused:
My best answer is a quote from my kids, "because"
2018 Ram 1500 Reefer Meal Delivery Truck (A64556)
2018 Ram 1500...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
LEEBOY  1000 PAVER (A67714)
LEEBOY 1000 PAVER...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
SPARTAN XBC173072-72" HYD BRUSH CUTTER (A65056)
SPARTAN...
