Split pipe on cutting edge of my MT125 for pushing snow.
   / Split pipe on cutting edge of my MT125 for pushing snow. #21
Anyone have experience with the Snow Edge from the Ratchet Rake folks?
Maybe you need some type of heavy rubber squeegee type material to complement the pipe.
Well maybe Doofy you hit the nail on the head here. Figure out a way to use the Edge Tamers that I have and put a squeegee of some sort to go between them. That would do the job. Also I'm thinking about maybe welding some "hard face" on this area of the pipe. This is definitely a work in progress. But the piple absolutely solved the problem of the cutting edge hitting cracks or joints. Plus in reality it's cheap.
   / Split pipe on cutting edge of my MT125 for pushing snow. #23
Lisa, I just watched a "Ratchet Rake Snow Edge" video and it appeared to do no better job than your split pipe. They only lasted about 32 hours. Looked like just a block of plastic. Sno-Way snow plows used a rubber edge and they worked well, I think. Unsure how long they lasted.
   / Split pipe on cutting edge of my MT125 for pushing snow. #24
Forget rubber or poly plow edges...Prices are prohibitive.
Well Doofy you and I must have watched that video together. Very interesting concept. They have a new 54" size that would be perfect for my tractor. They tested it to last 30 hours on their test rig. I would say my "split pipe" edge protector will last about 4 hours. I'm not giving up on my pipe idea but "The Show Edge" is very cool and won't damage the asphalt or concrete. But I can also improve my technique on using my "split pipe". Maybe I don't have to float the bucket and "set" it to just off the surface. If the surfice changes and you touch it's no big deal. I'm gonna save "The Snow Edge" product information but for now the pipe is working perfectly and I just have to lean to use it better. I'll make sure how it all goes.
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
LEEBOY 8510 ASPHALT PAVER (A60429)
LEEBOY 8510...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
