Split-dovetail car hauler trailer
/ Split-dovetail car hauler trailer #21
Looks really heavy duty. Are you going for 7000 or 10,000 capacity?
Capping the ends.
Ramps pretty much done.
/ Split-dovetail car hauler trailer #25
Very nice looking, can't wait to see the finished product !
/ Split-dovetail car hauler trailer #26
Very nice work, well done so far!
Test fit of the ramps. They are 6' long.
/ Split-dovetail car hauler trailer #28
I like the work you do.
Started on the tail light enclosures, these are made from three pieces of metal welded together, lots of grinding and sanding.
I cut out the opening for the main light (its going to have 3 different lights) with my jigsaw, its not perfect but you won't be able to tell once the light is mounted.
Main light sitting in place.
Light lit-up, what'd ya think I was gonna use those hemostats for?
Tongue and hitch, this was a pain getting everything lined up. I used a 12,500lb Bulldog hitch and 6" channel for the tongue.
Helper with her shoes on the right feet.
I measured and ordered two straight 5200lb axles (with brakes on both) from a local trailer dealer, when they came in they were 6000lb, he let me have them for the same price. I welded the hangers on with the trailer upside down then flipped it over and bolted on the axles.
Trailer is skinned. I used 14 gauge diamond plate for the decking. I used five 4x8 sheets. The cuts were made with both a cut-off wheel and my jigsaw. I used a whole tank of shielding gas welding the plate on. I used 1/2" metal for spacers on the cross members to level the plate to the outside frame.
Front bar (for lack of a better name) made and welded on. I capped the ends the same way I did the ramps.
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
(1) 48"X8' ADS DRAINAGE PIPE (A60432)
(1) 48"X8' ADS...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
John Deere 4044M (A60462)
John Deere 4044M...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
PONDEROSA PINE TONGUE & GROOVE (A60432)
PONDEROSA PINE...
