Split-dovetail car hauler trailer
   / Split-dovetail car hauler trailer #1
buggyman1
Platinum Member
Kentucky
Kubota B2150Hst
It probably would have been cheaper to just buy one, but after looking at what's out there for sale, I decided to build my own the way I wanted it. I got some basic ideas from a lot of different brands of trailers and pretty-much made up the design of mine from them. I used 6" channel for the main frame and 4" channel for the cross braces, I want it heavy duty. The deck is going to be 20 feet long and 83" wide, that's about as wide as I can fit in my shop. I also want inboard captive ramps (so they will stay put) and I hate to lug big heavy ramps around, some type of receiver on the front for a winch, recessed swivel D-ring tie downs, solid steel deck, 5200lb axles with brakes on both, recessed running lights wherever possible, custom tail lights, a receiver hitch on the back for various attachments and a few other things i'm sure. I started by making the floor perfectly level, then started cutting metal.
After squaring and clamping everything up...the first weld.
My helper.
Welding the cross-members in. I'm using a Millermatic 251 mig welder for most of the welds. They are set on 16" centers.
   / Split-dovetail car hauler trailer #5
Looks good so far... love the helper!
Smoothing out the outside surface welds with a grinder. Hopefully it'll look somewhat professional.
Thanks.
   / Split-dovetail car hauler trailer #8
Helper looks like ' Boots ' Last trailer I built I designed and made captured ramps , worked well but should have been a little longer. Looks better than pro to me. ---Trevor
Some light-weight ramps I made for my Rhino.
   / Split-dovetail car hauler trailer #10
Looks great, nice long ramps. Future use could include scaffolding, vehicle inspection from underneath, oil changes, etc ;-) I like it.
Most of the cross-braces in. I was going to put built-in, flush mounted motorcycle chocks in, but changed my mind after ordering one and seen how cheap-like they were made. I'll fill in the front with more bracing.
Dove-tail roughed in, flipping it over to weld the other side.
   / Split-dovetail car hauler trailer #13
I used a grinder and cut-off wheel to cut out the openings for the ramps and used a mag drill to drill for the posts. 1/4" plate was used for the flip-up doors.
When my children were about your daughter's age, the also wore their boots on the wrong foot..good memories.
I didn't even notice her boots until I went to post it to this thread.
For gussets I used cardboard to get the shape I wanted then traced it onto 1/4" plate, I then cut it out with a cut-off wheel.
Gussets laid in place and burned in.
   / Split-dovetail car hauler trailer #18
:thumbsup: Watching.
Next I started on the ramps. They are made from 1/4" thick square tubing with the center parts 3/16" thick square tubing, they are heavy.
   / Split-dovetail car hauler trailer #20
Have you seen these? Biker Bar
John Deere 4520 (A60462)
John Deere 4520...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
