Spike Aerator
/ Spike Aerator #1
carolinarider
Newberry, SC
Massey Feerguson 1250
I would like to purchase a spike aerator so pull behind my MF 1250 tractor. I have found a couple but one issue would be moving it from point A to point B and not having the spikes engaged.
Are there any what have a system that I can attach some wheels to so that it is raised off the ground while it is being moved from Point A to Point B?
Just for the record, I intend to use it to aerate some areas that have heavily compacted soil with the hopes that if I can get some water and nutrients down below the surface I can get some grass to grow.
/ Spike Aerator #2
Mine is a Frontier 6' CA2072 that is 3 point mounted. I made a couple of weights with from plywood forms and sackcrete that fit in the top tray. I had some u shaped pipe from an old round bale feeder that I cut off and cast into the top of them so I can take the weights off with pallet forks if desired.
Works well digs good plugs and I used it on my pastures and lawn each year.
There are other brands that make similar ones that are 3 point mounted. The only reason I bought this particular one is because it sat on a local John Deere dealers lot for several years, never moved. I stopped in one day and asked did they intend to sell it or did they just like to mow around it.
/ Spike Aerator
So, I assume that a 3-point hitch aerator will allow me to raise it up for transport. Is that correct?
/ Spike Aerator #5
I had a TORO 3ph unit. Must have weighed two thousands pounds! The stones areound here were quickly destroying the scoop type tips, so I sold it.
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
