Spike Aerator
/ Spike Aerator #1
carolinarider
Newberry, SC
Massey Feerguson 1250
I would like to purchase a spike aerator so pull behind my MF 1250 tractor. I have found a couple but one issue would be moving it from point A to point B and not having the spikes engaged.
Are there any what have a system that I can attach some wheels to so that it is raised off the ground while it is being moved from Point A to Point B?
Just for the record, I intend to use it to aerate some areas that have heavily compacted soil with the hopes that if I can get some water and nutrients down below the surface I can get some grass to grow.
/ Spike Aerator #2
Mine is a Frontier 6' CA2072 that is 3 point mounted. I made a couple of weights with from plywood forms and sackcrete that fit in the top tray. I had some u shaped pipe from an old round bale feeder that I cut off and cast into the top of them so I can take the weights off with pallet forks if desired.
Works well digs good plugs and I used it on my pastures and lawn each year.
There are other brands that make similar ones that are 3 point mounted. The only reason I bought this particular one is because it sat on a local John Deere dealers lot for several years, never moved. I stopped in one day and asked did they intend to sell it or did they just like to mow around it.
/ Spike Aerator
So, I assume that a 3-point hitch aerator will allow me to raise it up for transport. Is that correct?
/ Spike Aerator #5
I had a TORO 3ph unit. Must have weighed two thousands pounds! The stones areound here were quickly destroying the scoop type tips, so I sold it.
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
Kubota L6060 (A64126)
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
