Spendy toro groundmaster 72
/ Spendy toro groundmaster 72 #1
4720 OWNER
WEBSTER, MN
JD 4720
Sounds like most threads i have read here are pretty cheap (inexpensive) to fix lawn tractors. Have a toro groundmaster, just tore out the splines on center spindle of the mower deck, 72". $80 for the pully, $120 for the shaft, and as long as in there, $35 for the bearings. That is just the parts. Since i really do not like messing with retaining clips, $100 for the pro to put it all together again.
How are them apples!!
/ Spendy toro groundmaster 72 #2
I have a Toro Ground Master with a 62" deck and am looking for the shaft assembly for the deck where did you get the parts for the spline as i have been quoted $482 for the shaft itself??? Then the gear bax has 5/8 of an inch play equating to another $432 if it gets replaced or fixed.
2022 EZ-GO ELITE...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
JOHN DEERE C6R36" CORN HEAD (A64278)
JOHN DEERE C6R36"...
