Speed of JD 2720 in low range
   / Speed of JD 2720 in low range #1
logankelly
winona mn
jd2520
Looking for speed of JD 2720 in low range at pto rpm. Had a hand held GPS but that was a couple years ago. going to seed and fertilize about two acres and need to make sure of the speed, If possible would like to go 4mph to match the rate chart on spreader
   / Speed of JD 2720 in low range #2
According to the owners manual,
"Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard tires and operated at 2600 engine rpm.
Forward and Reverse - Range High 0-21.8 km/h (0-13.5 mph)
Forward and Reverse - Range Low 0-7.5 km/h (0-4.7 mph)
   / Speed of JD 2720 in low range #4
I have turf tires on my 2720. For me to go 4 mph I set the rpm's at 2200 and in low gear mash the peddle to the floor and put on the cruise control. 5 mph is reached with the same process and at 2700 rpm's. If you want to do it any other way, you will probably have to use a gps.
Load Master 27ft Tri-Axle Boat Trailer (A48082)
Load Master 27ft...
2013 Ford Escape SE SUV (A50860)
2013 Ford Escape...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2012 Jeep Compass SUV (A48082)
2012 Jeep Compass...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2012 Ford F-250 XL 4WD Flatbed Pickup Truck (A50860)
2012 Ford F-250 XL...
