Speed of JD 2720 in low range
   / Speed of JD 2720 in low range #1
logankelly
winona mn
jd2520
Looking for speed of JD 2720 in low range at pto rpm. Had a hand held GPS but that was a couple years ago. going to seed and fertilize about two acres and need to make sure of the speed, If possible would like to go 4mph to match the rate chart on spreader
   / Speed of JD 2720 in low range #2
According to the owners manual,
"Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard tires and operated at 2600 engine rpm.
Forward and Reverse - Range High 0-21.8 km/h (0-13.5 mph)
Forward and Reverse - Range Low 0-7.5 km/h (0-4.7 mph)
   / Speed of JD 2720 in low range #4
I have turf tires on my 2720. For me to go 4 mph I set the rpm's at 2200 and in low gear mash the peddle to the floor and put on the cruise control. 5 mph is reached with the same process and at 2700 rpm's. If you want to do it any other way, you will probably have to use a gps.
71061 (A49346)
71061 (A49346)
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
