Speed of JD 2720 in low range
   / Speed of JD 2720 in low range #1
logankelly
Bronze Member
winona mn
jd2520
Looking for speed of JD 2720 in low range at pto rpm. Had a hand held GPS but that was a couple years ago. going to seed and fertilize about two acres and need to make sure of the speed, If possible would like to go 4mph to match the rate chart on spreader
   / Speed of JD 2720 in low range #2
According to the owners manual,
"Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard tires and operated at 2600 engine rpm.
Forward and Reverse - Range High 0-21.8 km/h (0-13.5 mph)
Forward and Reverse - Range Low 0-7.5 km/h (0-4.7 mph)
   / Speed of JD 2720 in low range #4
I have turf tires on my 2720. For me to go 4 mph I set the rpm's at 2200 and in low gear mash the peddle to the floor and put on the cruise control. 5 mph is reached with the same process and at 2700 rpm's. If you want to do it any other way, you will probably have to use a gps.
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2012 Ram 3500 Crew Cab 8FT. Flatbed Truck (A48081)
2012 Ram 3500 Crew...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
