SPEED????? HELP
/ SPEED????? HELP #1
turbojerk
Gettysburg, Pa
2007 Cub Cadet GT2554
I'd love to get more forward speed out of my GT3204...
what can I do?
/ SPEED????? HELP #2
At max RPM/throttle your speed is fixed by the governor and gear train. Not much you can do, even bigger engine has no effect unless it has higher RPM capability. I am sure someone knows how to mess with the governor and gain a little. Guys make racers of those type machines.
Ron
/ SPEED????? HELP #3
Do you get full travel out of you forward pedal? If not there is some adjustment either at the pedal or where the rod heads off the pedal shaft.
/ SPEED????? HELP #5
what can I do?
You'll have to tell us more. Is it performing the way it should? Most LTs and GTs only travel 5 or 6 MPH at a maximum. They're for mowing and other similar uses, not much more. If it has slowed down recently, you may have a drive train or transmission issue.
/ SPEED????? HELP #6
And yea....Rising RPM's isn't the way to increase speed, if you're still going to use it to mow. Changing pulleys or tire size would be only option.
/ SPEED????? HELP #7
what can I do?
The forward and backward speeds are a function of the pedal adjustments. The linkage can be adjusted to decrease the reverse speed and increase the forward speed. I adjusted my 3235 for the slowest reverse speed I could tolerate which gave me higher forward speed. I also made a modification to the reverse pedal to give it a little more travel. Here is a link to that post:
https://www.tractorbynet.com/forums...14-cub-cadet-3000-series-slow.html?highlight=
Bob B.
Monosem Planters (A64126)
Monosem Planters...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
