SPEED????? HELP
   / SPEED????? HELP #1
turbojerk
Bronze Member
Gettysburg, Pa
2007 Cub Cadet GT2554
I'd love to get more forward speed out of my GT3204...
what can I do?
   / SPEED????? HELP #2
At max RPM/throttle your speed is fixed by the governor and gear train. Not much you can do, even bigger engine has no effect unless it has higher RPM capability. I am sure someone knows how to mess with the governor and gain a little. Guys make racers of those type machines.
Ron
   / SPEED????? HELP #3
Do you get full travel out of you forward pedal? If not there is some adjustment either at the pedal or where the rod heads off the pedal shaft.
   / SPEED????? HELP #5
what can I do?
You'll have to tell us more. Is it performing the way it should? Most LTs and GTs only travel 5 or 6 MPH at a maximum. They're for mowing and other similar uses, not much more. If it has slowed down recently, you may have a drive train or transmission issue.
   / SPEED????? HELP #6
And yea....Rising RPM's isn't the way to increase speed, if you're still going to use it to mow. Changing pulleys or tire size would be only option.
   / SPEED????? HELP #7
what can I do?
The forward and backward speeds are a function of the pedal adjustments. The linkage can be adjusted to decrease the reverse speed and increase the forward speed. I adjusted my 3235 for the slowest reverse speed I could tolerate which gave me higher forward speed. I also made a modification to the reverse pedal to give it a little more travel. Here is a link to that post:
https://www.tractorbynet.com/forums...14-cub-cadet-3000-series-slow.html?highlight=
Bob B.
2013 Ram 4500 4x4 Flatbed Truck, VIN # 3C7WRLEL2DG592574 (A48836)
2013 Ram 4500 4x4...
12-UNUSED LANDHONOR 25" X 185MM UNIVERSAL BKT PINS (A50460)
12-UNUSED...
2009 CATERPILLAR 930H WHEEL LOADER (A50458)
2009 CATERPILLAR...
Concentrated Car Wash Soap (Approximately 100 Gallons) (A48837)
Concentrated Car...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
