Speed Control Problem
   / Speed Control Problem #11
<font color=blue>Mine seem to only do it when I am headed UP hill under load</font color=blue>
I had the same thing happening. The pedals only seemed to stick going up hill. I greased the fittings on the pedals and haven't had it happen again. If it does, I'll look into adjusting the spring.
--Brad
   / Speed Control Problem #12
I don't think the cruise is supposed to work in reverse. You may want to check the air gap between the cruise control electro magnet and the plate. If it is too close, it can bind the forward control pedal so the tractor may not stop.
I crawled under the tractor to check out the electro magnet clearance and notice that the plate only half covers the magnet when the reverse pedal is depressed while it fully covers the magnet when the forward pedal is depressed. As a result, I'm curious if everyone has the same problem that I do....?????? Next time you all get a chance, set your cruise while backing up a slight incline under load.......does you tractor hold speed?
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2014 Ford F-250 (A55973)
2014 Ford F-250...
1667 (A57192)
1667 (A57192)
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
