Spare tire mount for my RTV .
   / Spare tire mount for my RTV . #1
wawajake
Canada
Kubota BX2660 , Kubota RTV X1100C
So this fall for bird hunting season we annually ussually go 20 or 30 miles deep into bush in Northern Ontario with relatives and our side by sides.. ( no cell coverage either) I was worried about a side wall flat tire occuring on sharp rocks we traverse across often. So I located a spare Kubota RTV rim from dealer and bought a tire from Princess Auto , and I had a extra scissor jack from my Shasta camper. So by using a reinforcement steel plate
1 " x 6 " 1/4 " drilled and bolted thru side of box, and rim held by one 6 inch long bolt, and also mounted scissor jack with a few wing nut bolts ( after grand daughter helped spray paint black) .....worked out great. If I don't say so myself ;)
   / Spare tire mount for my RTV . #2
Also carry Mutli-Seal product called flat-Out. Way better than the green slime. Plus it will fill a gash up to 1/2-inch wide. The military and semi truck drives use this stuff. It's liquid Kevlar.
Even if you change the first flat, the chances of having another is possible too. The formula is non-flammable and lasts 10years or more compared to green slim that ignites and only lasts 2 to 3 years.
Yes I agree and have similar product, in toolkit ( I can transfer from truck) however sidewall gashes are difficult animal that a spare tire alleviates.
   / Spare tire mount for my RTV . #4
That's something I really need to do is get spares for my RTV and Z-Force.
I've been lucky all these years, but some day I'm gunna end up having to sacrifice a rim and tire to get home, LOL
   / Spare tire mount for my RTV . #5
I like your sideboards Wawajake! Those look nice!
Well my RTV is no longer going to be a trail riding machine. I just ordered the K-Connect and snow blower for it and dealer is buying my Boss vee plow off it.
   / Spare tire mount for my RTV . #6
I echo @Paystar comment. Those are fabulous sideboards gonna make me some. Did you fabricate the steel or did you find the tube stock for the RTV? I find it harder to find accessories for my RTVX 1100 c than for my polarises. currently looking for new aggressive tires with rims
   / Spare tire mount for my RTV . #7
Have you checked out Orange Aftermarket?
And just a tip....if you are happy enough with the aluminum rims and atv tires offered from Kubota, get them through your dealer through Wholegoods. Will be WAY cheaper than you can buy anywhere else.
When I get tires for my tractor I get them through Wholegoods and you end up getting new rims for free basically.
   / Spare tire mount for my RTV . #8
Thanks...Good tip!
Thanks.....Sorry did not reply right away, ( wife passed away end of Nov , so missed post) .....the rtv side boards are cedar fence boards, sanded and varathaned, the uprights are maple wood cut to size to fit tight in Rtv sq stock that is part of box, painted flat black to match.
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
New/Unused LandHero Pallet of Binders/Chains (A51573)
New/Unused...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
