Spacers for Lawn Tractor wheels
/ Spacers for Lawn Tractor wheels #1
preacher1
Meta, Missouri
LS MT342HC
I have a slope that must be mowed across that I slide half off the uphill side to keep wheels on the ground. Has anyone put a spacer on a lawn tractor's wheels to widen it for stability? I have a John Deere 110, which is not a big tractor. Would loading the tires be possible?
/ Spacers for Lawn Tractor wheels #2
There are specs both from Deere and the transaxle manufacturer on allowable load weight available. Not sure w/o digging, but they aren't very much. More aggressive tire tread help?
It is just the tip over factor that worries me.
/ Spacers for Lawn Tractor wheels #4
While not a 110, this guy put on dualies :) He sells aluminum wheel spacers from 1" up so could give him a call and see what he says. Local dealer should be able to help also.
/ Spacers for Lawn Tractor wheels #5
My dad had tractor type tires on the rear and wheel weights on his 110.
/ Spacers for Lawn Tractor wheels #6
When I had my JD lawn tractor I filled the tires, 99% filled. I also have hills that I need to mow across. This improved traction and stability. It will reduce the life expectance of the trans-axle. I had to replace mine after 11 years which I considered fair
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
