southwest goosenecks
   / southwest goosenecks #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
Anyone familiar with Southwest goosenecks or Southwest trailers? I'm looking at their skid steer trailer 16' with 7k axles. Been using a Big Tex but was told SW was built heavier but still a lightweight, easy to tow trailer.
Anyone have any experience?
Thank you!
   / southwest goosenecks #2
Where are you located?
I've seen HotShot guys using them when I was in the business, never heard anything bad.
   / southwest goosenecks #3
I have a 28' Southwest gooseneck with drive over fenders and 8000# axles, single wheel.
Its around 10 years old and the only issue I've had was when I first bought it.
The u-bolts loosened on the axels after using it a couple of times and needed to be tightened.I pull a JD 6410 and a JD 332D with a mulching head and haven't had any problems. It handles the weight with no problem and pulls really well empty. The only thing I would change would be going with 17.5 wheels for a heavier weight capacity.
I'm near San Antonio.
Looking at the bumper pull 16' with 7k axles rated at 13k. I wanted a heavier equipment trailer but my max load is under 10k. they tell me the trailer weighs 2350 lbs.
I use a flatbed to haul my attachments and just pull my skid or mini ex on the trailer and work in a lot of tight areas so a short trailer has been great for the last 10 years. I used to haul with a 20 +5 gooseneck and it was too long for what I do.
I've been using Big Tex but had a lot of problems.. Had a magnum.. that was a stout trailer. Should have kept it!
   / southwest goosenecks #5
May trailers in Ada, Ok make a very good trailer, I still have the 1st one I bought from them in 97.
Another one to look at IMO would be Trailer Wheel and Frame, I had a 40' G/N made by them, it was light and stout.
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
UNUSED JCT QUICK ATTACH DIGGER ARM (A51248)
UNUSED JCT QUICK...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
2025 CFG Industrial 680 (A50123)
2025 CFG...
