Source of home type punch press??????
   / Source of home type punch press?????? #1
RonR
Kansas
2003 BX2200
Hi,
I would like to limit my drilling time on projects I make, and I have shop experience running a punch press. It is SO NICE to punch a 3/8, 1/2, or 1" hole or slot in steel when you are building stuff.
Unfortunately, I don't work there anymore (or have contacts inside), so I'm considering trying to buy a punch for the garage.
I've seen some, but they are pretty pricey. Cheapest I've found is like $4K. I can drill a lot of holes for that amount.......
Any ideas? THANKS.
Ron
   / Source of home type punch press?????? #2
I have a Scotchman 50 ton ironworker that will punch a 1 1/4 hole in 3/4" steel plus a lot of other nice cutting features. Shears 3/8" X 4" angle iron, 1/4" X 14" steel, 1/2" X 6" steel. I am spoiled when it comes to drilling holes now. I found a great deal on it because it was 3 phase. I am running it with a 3 ph converter and it runs great. Look for a 3ph unit, they can be cheaper.
They also sell a punch a Northern Tool for around $2500. Can find it cheaper on Ebay new.
If you are handy you could buy the punch and die sets and make a fixture to use them on a H frame press. Harbor Freight has the 20 ton presses for under $200.
   / Source of home type punch press?????? #4
Sweet press. I hate drilling holes (mostly 1" in 1/2" steel) and I have
paid shops to do it for me ($1/hole, plus driving there). I have seen
the $2500 presses, and I may eventually get one. Tools and dies add
a lot, too.
I have considered getting the tools and dies and using a cheap H-frame
press, as mentioned. The problem is, how to you retract the tool from the
work piece? My press is only 20T and I see needing 40T for the holes I
want. Still thinking about it. Meanwhile I use the plasma cutter......
Sure would be nice to have a 3PH mounted punch press........... Tractor could run the hydraulics...................
I'd have to fab a lot more stuff than I currently do to justify the price of buyinng one for $3K.............
THANKS.
Ron
   / Source of home type punch press?????? #6
Hmm, vertical wood splitter ...
   / Source of home type punch press?????? #7
work piece?
from what ive seen there is really no need to retract it from the hole.
When you puch (shear) a hole in the steel you only get about half way through or less and the materal gives and "explodes" out the bottom.
the return springs on the shop press should be enough. (i also have a 20T shop press but havnt gotten any dies for puching stuff... yet) :D
   / Source of home type punch press?????? #8
When the tool punches thru the work piece into the die, it becomes
imbedded in the work piece. When the tool retracts, it must be pulled
back thru the work piece, while the die and work piece are held down. A
fixture on the punch presses I have seen does this. Also the press pulls
the tool back under power. I do not know how much force it takes, but
I suspect more than the retraction springs of a run-of-the-mill H-frame
from HF tools. I have watched my 1" holes in 1/2" plate being punched
and the retraction force sure looks substantial.
Homebrew, that might have some potential!
Most of the cheapy presses I've seen appear to have too much slop in them to be useful as a punch press---unless I am missing something.
I thought you had to have the punch fairly well aligned to the die for it to work well. I know you don't want to have them out of alignment unless you like broken dies and shrapnel flying around the shop....................
Sure would like to hear from someone that has used a cheapy press for a punch press, and has had success in up to 3/8" steel..............
THKS.
ron
   / Source of home type punch press?????? #10
I think the die-to-tool alignment issue is important, but
readily solvable with the fixture one needs to make to hold
the die and tool in the H-press. Pulling the tool out of the
work piece is the bigger problem that I can see.
   / Source of home type punch press?????? #11
Last punch and die set I bought cost about $25. It's been about 2 years though. You would have to make a holding fixture for them to hold alignment. On my machine the punch comes through a piece of metal called a stripper. When the punch retracts it brings the material up hitting the stripper and removing the punch from the work. It takes some effort to do this. A fixture could have a place for a pry bar to seperate the punch from the work.
20 ton isn't going to punch very much, my 50 ton has a 3' arm coming from a 4" hydraulic cylinder. Quite a bit of leverage.
   / Source of home type punch press?????? #12
I have a Famco 6 ton punch press for sale. It's a flywheel type real punch press, not a hydraulic press. PM me if you're interested.
   / Source of home type punch press?????? #13
Mornin Ron,
I use this little punch at work quite often its nice for light duty stuff up to 1/8" thick. Anything thicker and you need hydraulic punch. But it can be gotten pretty cheap. Im thinkin a couple hundred bucks for a used unit. Here is a pic of it.
Scott, THANKS.
Most of what I would do is 1/8" to 3/8", and I don't have space for two, so I think I'll continue to wish for a hydraulic one.
Thanks for the idea though.
Ron
   / Source of home type punch press?????? #15
On a former employer of mine, they had a project of re-sheeting about 4 or 5 advertising poles around the country.
They were sheeted with aluminium sheets, with a U rail, brake pressed on top and bottom of the sheet. on these bent flaps they were bolted onto steel frames the size of an aluminium sheet, these sections were bolted together to make an 8 by 15 meter advertising surface, which were mounted in a triangle shape on poles of about 20 meter high.
Because of the hundreds of identical aluminium sheets that had to be bent and punched, the company installed a steel rail on their 4 meter wide, 300 ton brake press, on which 6 punch units were bolted. The punch units were C shaped simple things, and needed the brake press to push on top of all 6 of them, this meant that they could punch all 6 holes in one move of the brake press, each at the correct distance apart.
I dont know where to get these C shaped punch units but they align the punch dies correctly and can be compressed by a log splitter or shop press.
   / Source of home type punch press?????? #16
Look around OLD fly wheel punch presses can be had REAL cheap. Usualy the ones that wont meet OSHA specs. Sometimes they can be had for scrap value or even FREE. Take a look around the back of large shops and junk dealers. Good machine dealers wont even sell them if they dont meet OSHA specs. But be aware that these thing can be dangerous, they will punch a hole so quick that you eye may not even see it happen ;((
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
4-Wheeel Hay Rake (A56438)
4-Wheeel Hay Rake...
2022 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
