Source for this fan???
   / Source for this fan??? #1
GinNB
NB, Canada, eh?
2x Kubota M108S, M105S, 2x M9000, IH885, IH584, IH484, IH454, F3000, F3610, C50, JX70, Landini 5830, JD4630 sprayer
Has anybody seen a source for a fan that looks like this? This one came loose on the shaft, ovalled the center a bit, and wore out the blades on one side. It's cast and the vanes and center are roughly 1/4" steel. It's belt driven at a speed approaching 10,000rpm, so whatever I replace it with has to be well balanced. Diameter is 12" and it's roughly 3" wide. Shaft size is 1.25".
   / Source for this fan??? #2
Fan? I'd call that an impeller. It probably started out life moving liquid, not air.
//greg//
Good point Greg. I certainly haven't been able to find another "fan" that looks like this.
It is. It's normally run by an 18hp twin cylinder motor (well, a small oil pump is run by the same motor, but it doesn't take much grunt at all). I've tried a 14hp single cyl Honda but it loads it up fairly heavily.
   / Source for this fan??? #6
Google New York Blower. They make large blowers and heavy fabricated steel impellers.
Thx Harry, will do.
It's the fan off of a blueberry burner. I've done a more accurate calculation of the speed and it turns at 9000rpm. Local machine shop sources tell me that it'll be close to $1000 to fabricate one and have it balanced. :(
   / Source for this fan??? #9
I give up! What's a Blueberry Burner?? Sounds like something I might need!:D
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
71058 (A49346)
71058 (A49346)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
1263 (A50490)
1263 (A50490)
2012 International Semi Truck (A50323)
2012 International...
