Source for odd size rocker switches?
/ Source for odd size rocker switches? #1
Lil Foot
Kubota B7100DT
I need some Rocker Switches for the instrument cluster on my Mini Ex project.
STSP, 15a or 20a, lighted or not. Need (4).
I would like them to fit the existing holes in the panel, so I don't have to fabricate adapters & such.
Problem is, I can't find anything to fit the existing holes.
Depending on your measurement preferences:
.940" X 1.690"
15/16" X 1 1/16"
24mm X 43mm
Plenty of depth available, panel is .063", 1/16", or 1.6mm thk.
Any ideas?
/ Source for odd size rocker switches? #2
The last time I needed an odd size switch I found it on eBay. Amazon may be another option.
Tried both of them; lots of switches, but none that fit those holes.
Also tried Auto Zone, O'Riellys, Napa, Graingers, Surplus Center, Cycle Gear, Ace, HD, Lowes.:cry:
Closest I've seen yet, but I wish they had published the actual hole size necessary, rather than the OAL dimensions of the switch.
Thanks guys, I will check them out.
/ Source for odd size rocker switches? #11
West Marine or Defender? Marine switches. Waterproof, ignition proof, basically any marine supply will have a variety of switches, WM will be most expensive.
From everything I can tell, there are no switches available anymore that will fit correctly in the existing holes. Therefore I will pick new switches, and either make adapters to make new switches fit, (likely) or a new panel from scratch. (less likely)
The whole idea was to find switches that fit, so that I didn't have to invest a lot of time in this, because my time is not my own these days. If it was, a new machined aluminum, SS, & glass fabrication would be likely.
At some point, I will remove the broken plastic, and clean up the indicator lights and such, and cover with new plastic.
It don't have to be pretty, we ain't building a church here.
Thanks for all the input!
/ Source for odd size rocker switches? #13
Two ideas:
1) Get a regular rocker switch and see if it fits. That hole ain't too much bigger and it might fit just fine.
2)Nilight, and I presume others, has a thing called a switch holder that is basically a bezel for around a regular switch. You might need to enlarge the holes, but that is fairly easy.
/ Source for odd size rocker switches? #14
It looks like there is still a little meat around the holes. How about a file, Dremel, or nibbler (rented, HD enough to handle 16 ga) to enlarge the holes to the next larger size switch you have found?
/ Source for odd size rocker switches? #16
Switch adapters, if you room.
Thread documenting my mini ex project:
Skip to post #98 for the switch related parts.
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
White 18' Disc Harrow (A66408)
White 18' Disc...
Kubota L3901HST
Kubota L3901HST
2020 Honda 1000X-4 RTV (A65579)
2020 Honda 1000X-4...
