Source for odd size rocker switches?
/ Source for odd size rocker switches? #1
Lil Foot
Member
Kubota B7100DT
I need some Rocker Switches for the instrument cluster on my Mini Ex project.
STSP, 15a or 20a, lighted or not. Need (4).
I would like them to fit the existing holes in the panel, so I don't have to fabricate adapters & such.
Problem is, I can't find anything to fit the existing holes.
Depending on your measurement preferences:
.940" X 1.690"
15/16" X 1 1/16"
24mm X 43mm
Plenty of depth available, panel is .063", 1/16", or 1.6mm thk.
Any ideas?
/ Source for odd size rocker switches? #2
The last time I needed an odd size switch I found it on eBay. Amazon may be another option.
Tried both of them; lots of switches, but none that fit those holes.
Also tried Auto Zone, O'Riellys, Napa, Graingers, Surplus Center, Cycle Gear, Ace, HD, Lowes.:cry:
Closest I've seen yet, but I wish they had published the actual hole size necessary, rather than the OAL dimensions of the switch.
Thanks guys, I will check them out.
/ Source for odd size rocker switches? #11
West Marine or Defender? Marine switches. Waterproof, ignition proof, basically any marine supply will have a variety of switches, WM will be most expensive.
From everything I can tell, there are no switches available anymore that will fit correctly in the existing holes. Therefore I will pick new switches, and either make adapters to make new switches fit, (likely) or a new panel from scratch. (less likely)
The whole idea was to find switches that fit, so that I didn't have to invest a lot of time in this, because my time is not my own these days. If it was, a new machined aluminum, SS, & glass fabrication would be likely.
At some point, I will remove the broken plastic, and clean up the indicator lights and such, and cover with new plastic.
It don't have to be pretty, we ain't building a church here.
Thanks for all the input!
/ Source for odd size rocker switches? #13
Two ideas:
1) Get a regular rocker switch and see if it fits. That hole ain't too much bigger and it might fit just fine.
2)Nilight, and I presume others, has a thing called a switch holder that is basically a bezel for around a regular switch. You might need to enlarge the holes, but that is fairly easy.
/ Source for odd size rocker switches? #14
It looks like there is still a little meat around the holes. How about a file, Dremel, or nibbler (rented, HD enough to handle 16 ga) to enlarge the holes to the next larger size switch you have found?
/ Source for odd size rocker switches? #16
Switch adapters, if you room.
Thread documenting my mini ex project:
Skip to post #98 for the switch related parts.
FERGUSON PEANUT RE SHAKER, 3PT (A62130)
FERGUSON PEANUT RE...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2015 CATERPILLAR 259D SKID STEER (A62129)
2015 CATERPILLAR...
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
