Source For New Locking Pins On Pallet Forks
   / Source For New Locking Pins On Pallet Forks #1
donm1
N.E. Texas
Kubota MX4700, JD 1050
I was given a pair of 42" pallet forks rated @ 1,500 Lb each. The locking pins are missing from the forks. I just started work on the steel frame for my LA844 loader and would like to use the notch adjustment setup. Does anyone know of a source for new spring loaded pins?
Thanks in advance.
Don M.
Yes, that is very similar to pin I am looking for. I actually have 1 of the pins (minus the lift handle) and was hoping to find one with approximately the same dimensions. The one I have is fairly chewed-up so I may not be able to measure it exactly. I've tried searching for one on the web without luck so I probably just don't know the proper name for the part. Thanks for the quick response.
   / Source For New Locking Pins On Pallet Forks #4
Go to a local fork truck repair shop. They should have what you need.
   / Source For New Locking Pins On Pallet Forks #5
i asked a similar question a couple years ago and someone posted a link that had many styles. see if yours is there:
Fork Pin Kits
Thanks for the link Lostcause. That site has a Pit Kit that will fit my forks.
(APPROX 19) 4" X 10" X 49 1/2" THICK I BEAM (A51247)
(APPROX 19) 4" X...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
