Source For New Locking Pins On Pallet Forks
   / Source For New Locking Pins On Pallet Forks #1
donm1
N.E. Texas
Kubota MX4700, JD 1050
I was given a pair of 42" pallet forks rated @ 1,500 Lb each. The locking pins are missing from the forks. I just started work on the steel frame for my LA844 loader and would like to use the notch adjustment setup. Does anyone know of a source for new spring loaded pins?
Thanks in advance.
Don M.
Yes, that is very similar to pin I am looking for. I actually have 1 of the pins (minus the lift handle) and was hoping to find one with approximately the same dimensions. The one I have is fairly chewed-up so I may not be able to measure it exactly. I've tried searching for one on the web without luck so I probably just don't know the proper name for the part. Thanks for the quick response.
   / Source For New Locking Pins On Pallet Forks #4
Go to a local fork truck repair shop. They should have what you need.
   / Source For New Locking Pins On Pallet Forks #5
i asked a similar question a couple years ago and someone posted a link that had many styles. see if yours is there:
Fork Pin Kits
Thanks for the link Lostcause. That site has a Pit Kit that will fit my forks.
2020 JOHN DEERE CP690 LOT IDENTIFIER 190 (A53084)
2020 JOHN DEERE...
2013 John Deere 8360R MFWD Tractor (A53342)
2013 John Deere...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
2023 UNVERFERTH 632 LOT IDENTIFIER 165 (A53084)
2023 UNVERFERTH...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
