Source for bar/industrial type tires for lawn tractors
   / Source for bar/industrial type tires for lawn tractors #1
jlangton
Warren,Texas
Dad's JD 155C has issues with traction in wet or soft ground, and the crappy Carlisle turf savers are useless-the machine just slides all over and tears up the grass more than if it never lost traction. It has 22x9.5x12 tires on it,and looks as if you could run a slightly larger size. Where's a good source for a bar(R1) or industrial(R4) type tire in a size close to the OE size,and what's the average pricing for a pair of them?
JL
   / Source for bar/industrial type tires for lawn tractors #2
JL
Have you tried a search?
Info is here.
Info is here.
Yes, I have...The search function is terrible here like it is on most forums,and I get alot of jibberish when I use it. Your post is typical of what I deal with on forums where I have thousands of posts. The knee-jerk response is "use the search function" when a simple weblink or response that'll take as long as typing "use the search" would have sufficed. That response typically pisses people off and makes them have a bad attitude in general about the users of a particular forum when asking a simple question.
JL
   / Source for bar/industrial type tires for lawn tractors #4
If you have a Tractor Supply or other farm store near by you should be able to find the small ag tires.
TSC that I go to has both 23-8.50x12 and 23-10.50x12 in stock at all times.
I believe both are in the neighborhood of $50 to $55 each.
Thanks for the courteous and informative reply. That's all I was looking for, and hadn't thought about Tractor Supply-there's one local, I'll run by and see what they have.
JL
   / Source for bar/industrial type tires for lawn tractors #7
   / Source for bar/industrial type tires for lawn tractors #8
*a simple weblink or response that'll take as long as typing "use the search" would have sufficed.
**That response typically pisses people off and makes them have a bad attitude in general about the users of a particular forum when asking a simple question.
JL
*To do that I would have had to do a search myself. I figured you could do that as easy as I could. Sorry you took my post out of context and let that offend you.
** I found you reply arrogant and insulting so now I guess we're even.
   / Source for bar/industrial type tires for lawn tractors #10
http://www.tiresunlimited.com/specialty_lawn_utility.htm
This place carries all of Carlisle's lineup and others- the 23x10.5x12 lugs will fit your rims fine, they have a few styles available, prices vary on design. TSC my way has very few tires for small tractors.
-Fordlords-
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
Army Semi Trailer (A50774)
Army Semi Trailer...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
