Source for bar/industrial type tires for lawn tractors
   / Source for bar/industrial type tires for lawn tractors #1
jlangton
Warren,Texas
Dad's JD 155C has issues with traction in wet or soft ground, and the crappy Carlisle turf savers are useless-the machine just slides all over and tears up the grass more than if it never lost traction. It has 22x9.5x12 tires on it,and looks as if you could run a slightly larger size. Where's a good source for a bar(R1) or industrial(R4) type tire in a size close to the OE size,and what's the average pricing for a pair of them?
JL
   / Source for bar/industrial type tires for lawn tractors #2
JL
Have you tried a search?
Info is here.
Info is here.
Yes, I have...The search function is terrible here like it is on most forums,and I get alot of jibberish when I use it. Your post is typical of what I deal with on forums where I have thousands of posts. The knee-jerk response is "use the search function" when a simple weblink or response that'll take as long as typing "use the search" would have sufficed. That response typically pisses people off and makes them have a bad attitude in general about the users of a particular forum when asking a simple question.
JL
   / Source for bar/industrial type tires for lawn tractors #4
If you have a Tractor Supply or other farm store near by you should be able to find the small ag tires.
TSC that I go to has both 23-8.50x12 and 23-10.50x12 in stock at all times.
I believe both are in the neighborhood of $50 to $55 each.
Thanks for the courteous and informative reply. That's all I was looking for, and hadn't thought about Tractor Supply-there's one local, I'll run by and see what they have.
JL
   / Source for bar/industrial type tires for lawn tractors #7
   / Source for bar/industrial type tires for lawn tractors #8
*a simple weblink or response that'll take as long as typing "use the search" would have sufficed.
**That response typically pisses people off and makes them have a bad attitude in general about the users of a particular forum when asking a simple question.
JL
*To do that I would have had to do a search myself. I figured you could do that as easy as I could. Sorry you took my post out of context and let that offend you.
** I found you reply arrogant and insulting so now I guess we're even.
   / Source for bar/industrial type tires for lawn tractors #10
http://www.tiresunlimited.com/specialty_lawn_utility.htm
This place carries all of Carlisle's lineup and others- the 23x10.5x12 lugs will fit your rims fine, they have a few styles available, prices vary on design. TSC my way has very few tires for small tractors.
-Fordlords-
New Idea Pull Type Hay Rake (A50515)
New Idea Pull Type...
2 Axle Deckover Trailer (A50774)
2 Axle Deckover...
2012 Ford F-150 (A50120)
2012 Ford F-150...
JOHN DEERE 1050 TRACTOR (A51243)
JOHN DEERE 1050...
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
