Soucy Tracks
/ Soucy Tracks
Needless to say if you really understand 4 wheel drive it does have it. Except the wheel that does not spin only has as much tourque as the wheel that is spinning. It does not have differ lock in the front.However that project is on the back burner right now. A machinst buddy and me are going to make that front differ lock.
I think that the places that I was trying to get it stuck will be frozen solid this morning. It is minus 6. The tracks are 14" wide.
/ Soucy Tracks #12
Deelope,
I am curious also, what is that spring contraption under the belly of the RTV, has it something to do with the tension of the tracks ?
/ Soucy Tracks #13
Except only the wheel that does not spin has as much tourque as the wheel that is spinning..
Wheels that don't spin have zero torque. :)
/ Soucy Tracks
TWO GUNS said:
Deelope,
The spring acts as a shock absorber. Just like the rubber inflated tire would if you hit something solid.
/ Soucy Tracks #15
I sure do like your bed rail extensions. Did you build those yourself?
/ Soucy Tracks #16
Would the st-110 soucy tracks made for the rtv 1100 fit on the rtv 900 because I found some used? Thanks
/ Soucy Tracks #17
Deerlope , I just got a set used and I can't figure out how to get them on . I got the back figured out but not the front i can't for the life figure out the front. I may not have all the parts. I bought on eBay for a song and a little dance ,but it may not pan out for me. Is there a bracket of some sort that you have to have for the front axels ?
/ Soucy Tracks #18
As I understand it the only difference is the back track is a little longer on the110's than the100's . They will fit according to the sales rep Peter .......I forget his last name but he is listed on soucy web site
/ Soucy Tracks #19
Check for the dealer of your tracks and see if you can source a parts or install manual. Most companies have on-line manuals or can be found by googling.
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
Zero Turn Mower (A59231)
Zero Turn Mower...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2020 DRAGON ESP...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
