SOS HELP needed for electrical problem Kohler Engine
   / SOS HELP needed for electrical problem Kohler Engine #1
gunslinger69
kubota 295dt
I have a problem in not being able to start the Kohler engine on my woodsplitter. It worked fine all last season and have not started at all this year. When I turn the starter switch there is nothing. When I bypass the switch and hot wire the Solenoid to the starter, the starter will turn the engine but it will not fire. I pulled the plug and there is no spark when I hot wire it. What are the possible sources of the problem? I changed out the coil, condenser and checked the points. SOS I am having a Hip Replacement in one month and need to split a ton of wood ahead of that. Thanks in advance.
   / SOS HELP needed for electrical problem Kohler Engine #2
Are you getting 12V to the coil with the key switch on? Check it with a meter or test light.
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
BROWN MPT-30 LOT IDENTIFIER 64 (A53084)
BROWN MPT-30 LOT...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2016 JOHN DEERE R4038 LOT IDENTIFIER 181 (A53084)
2016 JOHN DEERE...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
