Sometimes the little things mean a lot. . .
   / Sometimes the little things mean a lot. . . #11
I added a swinging cup holder designed for an ATV,
Bill
I keep saying I am going to do this. The build in cup holder is too wide. Does not hold a water bottle in place. It bounces out about 3 seconds in to your drive.
   / Sometimes the little things mean a lot. . . #12
Weld on bucket hooks are a necessity especially if you don't have pallet forks
   / Sometimes the little things mean a lot. . . #13
Adding dye to hydraulic fluid (if you have a sight glass)
What is the best dye to use? Is there a specially formulated dye for hydro oil? And, what color is found to be most visible?
I am not sure what a swinging cup holder is, but will check it out. This is the one I have - it can bounce out, I suppose, if you are really on rough ground but it has worked well for me - magnetic. I have also used a "stuck cup" in the past but can't find it now.
Amazon.com: Master Magnetics Black Magnetic Cup Caddy, Model# 7583: Automotive
I ordered the dye from John Deere. The product is MT3668 if anyone is interested. $5.07 per bottle - one bottle is enough. Made a world of difference in being able to see the level mark in the sight glass. Very frustrating before I added this. Will show red.
   / Sometimes the little things mean a lot. . . #16
That looks deep enough. The one built into my tractor is shallow and wide so driving over gravel would knock the bottle out. The roughest ground I have is ground that used to be row crops. That is going to be flattened soon anyway, but the stock cup holder sucks.
   / Sometimes the little things mean a lot. . . #17
That seems to be what everyone uses. Don't you wonder though, since Kubota has several tractors that use a sight glass, why on earth don't they sell the little bottle of dye insteading of making everyone go over to the JD dealer where they could look at tractors?. Ain't they got no marketing sense?
   / Sometimes the little things mean a lot. . . #18
Just got a stick on digital clock to put on the window.....Its easy to know when its dark but without a watch its hard to know when to knock off before the 10 o'clock fire restriction.:thumbsup:
   / Sometimes the little things mean a lot. . . #19
Good list Beowulf. And you could add a rear view mirror. Got a second tractor this spring w/o a mirror. I didn't realize how much I used it until there wasn't one to use.
gg
You are costing a lot of us the price of a mirror! Or two!
   / Sometimes the little things mean a lot. . . #20
Where have you guys mounted the mirror? I have a Kubota L2800, fel, no cab. I have a nice sturdy mirror from a forklift but never could determine a good place.
LOT: Assorted Pry Bars & Punches (A59076)
LOT: Assorted Pry...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
Terms and Conditions (A55272)
Terms and...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
