Sometimes it's worth it to hire a land surveyor
   / Sometimes it's worth it to hire a land surveyor #21
Just to add to the misery..
My little parcel is laid out Meets and bounds on three sides. but the north side line is a compass direction.
It was laid with a compass. and all the declination add on's associated.
The town map / deed map. uses "true North, not magnetic North.
There are a couple of lillies planted at each end of the line to mark the line my neighbor John and I have agreed on. ;-)
Won't hold in a court of law, but works for us!
ps
I sat as selectman in our small town for two terms. Land and lines can be a big division between friends, family and neighbors.
   / Sometimes it's worth it to hire a land surveyor #22
I get a survey in my name on everything I buy and make it a contingent in the contract that I must be satisfied with the survey.
The only parcel that doesn’t have a survey done at the time I acquired the property is the “old home place”. That was last surveyed in the 1920’s.
I did learn from the mistakes of others. Doesn’t mean I won’t have a problem somewhere, sometime. Just, hopefully, lessens the risk.
In cases where there are going to be improvements- especially buildings- anyplace near the lines I wouldn't even consider proceeding without good monumentation. My cousin had an abutter drill a well on his side of the line. He only has 4 acres, they have less than that.
I know of a case in South Portland years ago where they were building a McMansion and when it came time to refinance to pay off the construction loan, the mortgage inspection determined that the house was 11 inches too close to the property line. They applied for a variance but one of the abutter's wouldn't sign off on it so they had to move the building. When working close tolerances like that it would be cheap money to have the foundation laid out by a pro.
   / Sometimes it's worth it to hire a land surveyor #24
We're good on the right. That neighbor is a naked gardener like me. We know the liine +/- 10 feet. That's the easement for maintenance anyway.
Neighbor to the left is a pissant territorial rat. Had stakes put in about every 75 to 100 ft down the line. Neighbor on the other side removed them! I planted shrubs on my side of the stakes. Asked him whether he wanted me to mow for the Jap stilt grass down the back hill. "No, don't want your tractor on my land!" So, the wife started lining up logs along the line to keep my tractor off his precious land.
He cut our phone line in 2 places while planting trees. Phone company came out to run a new line. He stood on his land and declared HE did not have an easement. We looked it up. It's 10 ft +/- for utility and drainage easement state wide and likely country wide. Phone company later came out and figure out how to run a new line just on our property.
   / Sometimes it's worth it to hire a land surveyor #25
I am very nervous of my situation. distances weren’t adding up after buying my lot two miles down a dirt road. The surveyors came and the corner on the intersection is actually in the center of the roadway. It is a dirt road. The lot was treed and during the course of the last 5 years I cleared the lot enough to install the driveway, build a house/garage. I piled my wood down there, trailer, tractor etc as often I could not turn or needed space for cement-trucks further up the driveway etc. I had to put a pickup load of wood down on the corner, which was on the edge of the road way but maybe 6-8 feet from one side of my boundary and maybe 25 feet inside my other boundary being on a corner. They sent me an email last summer and said someone was having issues with wood but at a different lot number. a Lot that doesn’t exist in there. My thoughts were, well you should find out what lot their really talking about and if it is mine I can accommodate . But I didn’t. I just said any wood I had was inside my boundary’s and that I wasn’t planning to leave it there over the winter. This was in the summer. The next morning I go out there and they bull dozed it into the ditch. I was planning to put a street lamp at least out A little further to prevent more migration of the turn. However yesterday they spread recycled asphalt around the turn It use to be a logging road turned cottAge area. The logging company had a “right of way” designated for a the Road and is exceptionally wide. I’m thinking 60 feet or more. Yet the road which is approx 30 feet wide leaves the right of way and crosses my corner. My survey clearly shows the narrow road, leave the wide right of way on paper. I also showed this to the husband of the recently elected president of the road association last year. He assumed it was half the road on my lot, half the road on the other lot across from me. But I showed him that no, it’s a right of way that separates me from the guy across the lot and at that corner it’s exceptionally wide. Despite the road only being 30 feet or so.
From your sketch it would appear that you own to the center of the roadway (layout), but you likely do not have a right to block that roadway/layout.
Where in Nfld. are you?
I was a USN pilot stationed at Argentia in the mid 60's.
I have great memories of my Nfld. days.
The Trans-Canada highway was still gravel from Gander to Corner Brook.
   / Sometimes it's worth it to hire a land surveyor #26
If it’s an old county road the survey probably would put the property line somewhere in the road. No, he cannot block the road. Yes he still pays tax on the portion in the road.
   / Sometimes it's worth it to hire a land surveyor #27
I did not suggest otherwise!
Please keep in mind that he's in Canada so different rules may apply... just as they do from state to state.
   / Sometimes it's worth it to hire a land surveyor #29
Here's your problem:
   / Sometimes it's worth it to hire a land surveyor #30
I believe a survey is a good idea. I bought 14.37 acres 5 years ago with the idea of building my retirement home there. I looked into hiring a surveyor and found out what they cost. My place is essentially a square, gently sloping and heavily forested. I have neighbors bordering on all sides whose properties have all been surveyed. $40k-$50k to survey my property!!!!!
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2022 ATLAS XAS188 AIR COMPRESSOR (A52472)
2022 ATLAS XAS188...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
