Sometimes it's worth it to hire a land surveyor
   / Sometimes it's worth it to hire a land surveyor #61
The land we bought 2 years ago was listed by the owner as 52 acres, which they had owned since the mid '80s.
Best I could get using Google Earth was maybe 35 acres.
And of course, we made our purchase offer contingent on completion of a current survey...
It turns out the owners had been paying "52 acres worth" of taxes on 34.5 acres of actual land...for over 30 years...
That's not uncommon, although one of the more extreme cases. A lot of old deeds were "more or less"; usually within 10%.
There's an old farm two towns down which was originally around 500 acres; the owner split it up years ago and sold (6) 100 acre lots from it. Land was cheap though so nobody checked.
   / Sometimes it's worth it to hire a land surveyor #63
My Dad purchased 63 acres which has grown to over 71 acres on the tax rolls. The highway splits off a small corner of the property and the corner is listed as part of his deed. The county recently sold that corner for back taxes, and Daddy saw some activity over there, so wandered over to see what they were doing. Once he determined that they were fixing to start clearing it for a house, he advised them that they might want to wait until the courthouse opened back up on Monday, unless they wanted to pay top dollar for every tree, bush, or blade of grass. The county reversed the sale...
David from jax
   / Sometimes it's worth it to hire a land surveyor #64
In Texa
In Texas they could likely go back 5 years to correct those property taxes.
   / Sometimes it's worth it to hire a land surveyor #65
Which is why I always recommend a new survey with the contract contingent on the survey. I have had cases where it went both ways. Usually if the new survey is short a bit and the buyer is ok with what they see on the ground they are open to keeping the price the same. But if it’s contingent on the survey and the contract is written properly they get it for the per acre price.
   / Sometimes it's worth it to hire a land surveyor #66
In Texa
I think that whenever the politicians decide they want to assess the value of property, they should be required to get an unbiased survey done. It would get these issues discovered earlier and maybe reduce the frequency of them doing backdoor tax increases.
   / Sometimes it's worth it to hire a land surveyor #67
Everybody can tell you where your lines are; your neighbor, the previous owner, the realtor; yet if you aren't proficient at reading deeds, a good surveyor is the best person to talk to.
In this state, only a registered survey is legally binding in any property dispute. Just had a 152 acre piece surveyed and staked and I went back and drove steel Tee posts at the stake locations. Was it cheap, no but it eliminates any disputes with adjacent land owners.
   / Sometimes it's worth it to hire a land surveyor #68
Of course you do realize that your steel T-posts are referred to as "witness markers", and are not recognized as legal boundary markers.
If you had your surveyor set concrete bounds, they would be legal boundary markers, and another survey might not be necessary when the stakes rot away.
   / Sometimes it's worth it to hire a land surveyor #69
Surveyors often call them “stakes” but for property boundaries most surveyors use rebar or pipe or some other metal rod. Some states require a cap on top with the surveyors number on it.
T posts near the surveyor rod is not a bad idea but has problems. If too close it makes it hard to find the surveyors rod with a metal detector. If you set the T post 6” or a little more away that helps. The best thing is those flat about 6 inch wide fiberglass Orange posts like utility companies use. You can get them printed with a label that says “SURVEY MARKER NEARBY, DO NOT DISTURB”.
   / Sometimes it's worth it to hire a land surveyor #70
"CB's" ......concrete bounds are used extensively in much of NE.
Pieces of rebar with surveyor number caps are used in many other areas.
2003 Big Tex 10PI...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
Mccormick Hammer Mill (A57454)
Mccormick Hammer...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A57453)
2007 Isuzu FTR...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
