Something I don't understand about applications of below 40hp tractors
   / Something I don't understand about applications of below 40hp tractors #101
Depending on hard the ground is I have to add some front weight on it. Got bigger tractors, but on smaller garden plots it is handier.
   / Something I don't understand about applications of below 40hp tractors #102
Pulleys and levers.
It's all pulleys and levers now.
   / Something I don't understand about applications of below 40hp tractors #103
Well I have no trouble pulling 2-14s with my John Deere 790. Mine is the 27hp version, but I do have filled R1 tires on the back with a loader mounted. Having 3pt makes a lot of difference.
   / Something I don't understand about applications of below 40hp tractors #104
I read you don't plough with any tractor under 40hp. At least maybe not on a new unworked field. Don't know if that's right, but it is what I have been reading on more than one site.
If you don't have a front loader or a lawn cutting pull behind implement, what do you use them for? For example, I found a good price on a Kubota B6000e. It is only the tractor. I can only cut the grass with it?
Are all the old tractors over 40hp?
Edit:. I read the Kubota was 10.5 hp. My jd L110 is 17.5, but no pto. I don't know what I'd do with the Kubota.
I plowed with a 12 hp Gravely using a Gravely rotary plow. If they made a rotary plow for the 3ph, one could easily plow with a 4wd SCUT or MCUT. I used a soil ripper from an old JD M converted to 3 ph on my 18.5 hp JD 4010 on my garden that had been previously plowed with the rotary plow. Then took off the soil rippers and put 2 opposed discs onto the tool bar and made 20 raised rows.
Can brush hog, mow, wood chip, run box blade and back blade, snow plow or FEL/BB: all with as little as 18.5 hp in 4wd tractors.
   / Something I don't understand about applications of below 40hp tractors #105
I have a compact 38 hp JD. Tires are filled and equipped with FEL & BB. I am clearing an overgrown field for a driveway - giant shrubs and trees to 6+ in diameter. The job would take a pro with heavy equipment a half day to a day. I have worked it for a few hours most days for a week or so and have made great progress. I have to dig out (piranha bar on FEL) when bigger units can push over. I have also torn up sod with the BB with teeth down. I think you can do most anything with a small tractor if you are careful and work incrementally. I enjoy the experience and am saving money. I use my tractor hard but it is now 10 years old and has never needed maintenance beyond the routine stuff in the manual.
   / Something I don't understand about applications of below 40hp tractors #106
I grew up with a 7hp Gibson garden tractor, we used to plow with it, single bottom 8 or 10 inch I think. Rope start Wisconsin engine, you hoped would not backfire when you pulled on the starter rope, would about rip your fingers off if it did!
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
