SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,332
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Ever tried it? Admitedly, mine is easy cuz its always enabled and I have full control from full DC off to full DC sense with the draft lever. I think by pulling the lockout pin you will be similar. Give it a try. There are real benefits to this live adjustment when grading.Dougster said:The problem is the simple geometry of the situation... my tractor vs. their land. Admittedly, my tractor is probably too big (i.e., too long) for most of the "back yard" work I find myself doing.One second my rake is in the ground doing fine and the next minute it is all plugged up with roots & rocks or up in the air. I have to actively monitor it and keep it clear. This is not just a case of setting proper depth once, being able to forget about it... and allow it to adjust itself to keep that depth. This is a problem of making almost constant adjustments to follow the contour of some of these relatively small, uneven, under-reconstruction back yards.
Remember... half or more of the reason I am there is to straighten out these silly yards... and usually that means I have been digging and/or placing material... so don't expect them to be uniform enough in the initial stages to behave nicely as I'm trying to do the smoothing out work!![]()
Dougster
larry
