Someone Please Translate This!
   / Someone Please Translate This! #21
BTW if you forget draft control on and attach a PHD to the center hole of the top link bracket instead of the top one, you are in for a surprise. The 3ph has enough force to push the PHD up until it wedges the tube between the toplink bracket sides, spreading them.
Oh Lordy... not a good thing! :eek: Thanks for the tip... but I think I'm convinced to leave draft control off and that lower bracket pin in the general implement "A" position until I become smart enough to really understand what I'm doing. :)
Dougster
   / Someone Please Translate This! #23
Dougster, have you figured the draft control out yet.
I think I'm getting the idea... but as a practical matter, I don't see where it's going to be super-helpful or worth the effort on the small jobs I get to do... usually with the owner standing there and generally uneven, hilly terrain with lots of obstacles. Property owners expect to see you paying close attention to every aspect of what's happening... no "set it and forget it" mode on anything so far. These are not zillion acres jobs like out in your part of the country. I measure all of my jobs in square feet!!! :(
Dougster
   / Someone Please Translate This! #25
Yoy can set the draft control for the 3 point so it "floats" (similar to the float on a FEL). This is to allow the inplement to stay as level as possible despite the tractor going up and down to the "lay of the land". My 15 series Mahindra does not have draft control and I have yet to use the 3 point since the back hoe has never been dismounted.
Get that backhoe off of there and have some 3-point fun! :) Backhoes are very cool... especially with thumbs... and provide badly needed ballast (as I found out this past weekend). But 3-point opens up a whole new world. :D
Draft may be great for some, but it's just not necessary or even appropriate for my work up here in New England... at least so far. I don't think you are missing much... although I will admit that with a lot of relatively flat land and certain implements, it could clearly be useful.
Dougster
   / Someone Please Translate This! #27
My ol' 9N has given me many, many hours of draft control experience. The back hoe is no match for the 3 point for operational enjoyment. Its like comparing ridin' Schwinn to a Harley.
Well, there ya go! :) Didn't notice that you owned an old 9N for the last gazillion years! :) You have forgotten more about 3-point than I will ever know! :cool:
Dougster
   / Someone Please Translate This! #29
Dougster
I would expect that the draft control would be very beneficial on uneven, hilly terrain.
The problem is the simple geometry of the situation... my tractor vs. their land. Admittedly, my tractor is probably too big (i.e., too long) for most of the "back yard" work I find myself doing. :rolleyes: One second my rake is in the ground doing fine and the next minute it is all plugged up with roots & rocks or up in the air. I have to actively monitor it and keep it clear. This is not just a case of setting proper depth once, being able to forget about it... and allow it to adjust itself to keep that depth. This is a problem of making almost constant adjustments to follow the contour of some of these relatively small, uneven, under-reconstruction back yards.
Remember... half or more of the reason I am there is to straighten out these silly yards... and usually that means I have been digging and/or placing material... so don't expect them to be uniform enough in the initial stages to behave nicely as I'm trying to do the smoothing out work! :)
Dougster
DIRT DOG 88" PULVERIZER (A51243)
DIRT DOG 88"...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
