Some PT-425 videos
   / Some PT-425 videos
kmaz said:
Hey kent, i didnt anticipate it working as smoothly as it does either. The key is precise placement of the drilled and tapped hole. The threaded star knob is just shy of touching the steel block mounted on the underside of the joystick when its not being used. When you want to lock yourself in float simply push the joystick to float , turn knob a half turn and it cant come out of float because theres a bolt in the way.
Kris
Thanks, Kris! :) I'll have to look closely and see if I can determine how to locate a threaded knob. I have a knob, if I can figure out exactly where to put it...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
UNUSED LANDHERO 1H-1W21 1" AIR IMPACT WRENCH (A57193)
UNUSED LANDHERO...
Wheel Loader Coupler (A56469)
Wheel Loader...
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
Caterpillar 259D3 (A53317)
Caterpillar 259D3...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
