Some one needs to do this in orange
/ Some one needs to do this in orange #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
Snow Vehicle Concept (1924)
Go to this site and watch this incredible 1924 tractor. One of you guys that weld and modify their factory original Kubotas need to add this to their Kubota. Probably will only be needed in snow states.
/ Some one needs to do this in orange #4
I WANT ONE!!!!
PS. Poor horse...
/ Some one needs to do this in orange #6
Aaaaaagghh...where's the ROPS!!??:p
You are right...poor horse!!!
Deano
/ Some one needs to do this in orange #7
wow -- that is cool - i want one too!! poor horse though.
After seeing the "miracle snow tractor" Its surprising I havent heard of them or seen them around since.:confused: what caused it to fail ?
/ Some one needs to do this in orange #8
My guess is that they can only go on dry ground in an emergency??
/ Some one needs to do this in orange #12
The Russians and English had those things too. The english model was for traversing mud flats near the channel and the russian one was used in swamps.
If I recall right the drums are expensive, wear quickly on anything but snow and were quickly overtaken by tracked design such as JA Bombardiers.
/ Some one needs to do this in orange #13
That was great! Thanks for sharing the link! My 5 year old wants to know if it is a "hybrid"? Poor Horse!!
/ Some one needs to do this in orange #14
Don't think that would work well for sidehill use. Flat land or straight up and down hills would be fine. Looked like it slid into the fence bordering a shallow grade at one point and damaged the fence.
Maybe keel-like runners that could be lowered on hillsides would help.
OK Bob. Are you accepting the challenge to build one? You can promote it as the one with Bob Young Improvements or how yours can do up, down and across hillsides. I think you will have enthusiastic support and maybe a couple of dollars support from this forums members. I'm in for $5. You know we have tracks now that have rubber so strong that they last a long time so my contribution is use rubber for the "whatever their called" splines? Come on Bob, do it!
/ Some one needs to do this in orange #16
Actually, the mechanics of it are ingenious. I can see it being refined a bit and made more durable.
Looks like the rear/differential is the major component to it. Off hand it almost looks like the entire rear was swapped with his modified independant drive unit. I'm highly impressed with the use of the OEM steering linkage to control the independant drives. The video indicated that both the tractor and car can be "easily" readapted to wheeled operation, so if the rear drive unit is a complete replacement it must also have "normal" wheeled drive capability too.
Unfortunately it only has a very limited market and that was probably it's ultimate downfall. I can see it being successful in heavy snow areas as well as bogs.
It would be neat if more info could be found on it and whether there are any working models of them still around somewhere......
/ Some one needs to do this in orange #17
I have a book at home on the history of tractors, maybe only Ford tractors. There is a photo of one of these in there, so at least one survived. Certainly is ingenious. I can see it with polyethylene drums and rubber ribs. Might even float and travel on water?
My neice lives in Anchorage, Ak , not Anchorage, Ky, and she responded immediately that she wants one after viewing the video.
/ Some one needs to do this in orange #19
pretty cool would be fun to pull sleds behind for the kids
/ Some one needs to do this in orange #20
I can see doing a small one person version with poly drums and a snowmobile engine. That has the potential to be much lighter than a typical snowmobile which would provide stunning performance.
