some newbie questions for b3200
   / some newbie questions for b3200 #11
Ductape,
Thanks for the reply,
Your B3030 operator manual is quite different than my B2320. The B2320 manual states: ''If one of the rear wheels should slip, step on the differential lock pedal. Both wheels will then turn together, reducing slippage.''.
I assume both tractors have similar diff lock systems. Maybe it's an overlook from Kubota or there is an actual design difference. To be safe I will be using the most conservative method from now on, I will wait until both wheels have stopped before engaging the Diff Lock pedal.
Thanks again for checking your manual
Gyro
   / some newbie questions for b3200 #12
thanks for the replies. i wonder if there is an issue with my rear end, because like i said, both rear wheels spin together in 2 wheel drive without the diff.lock pedal being pressed.
one other issue i forgot to mention in my post. when testing the starting interlocks, i noticed that the one that prevents the tractor from starting without the clutch being depressed does not work. i notified my dealer who tested a couple other tractors and found this same issue. he also notified a local rep. have not heard the outcome. any other b3200 owners have this issue?
Dcosto,
My B2320 HST also starts without the clutch being pressed. I kind of like it that way.
Gyro
   / some newbie questions for b3200 #13
yeah, I always start my standing on the ground to let it warm up - then I go do something before I get on it. Of course you are not supposed to, you could be arrested by the tractor police. :) Maybe just the gear models need the clutch pushed in - to prevent it lurching forward if it's not in neutral?
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
1049 (A50459)
1049 (A50459)
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
