Solid State Relays SSRs, anybody use them for HEAVY Loads?
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #21
Not sure if there's a typical usage for shunt trip breakers.
They're typically used when a full relay or contactor isn't required, usually when you just want a way to (automatically) turn off a circuit, but don't need it to automatically turn on.
Load shed is one usage, another might be if a (fire) alarm is triggered and you want to cut the power to something.
Because they are "one way" and manually resetting is required, they're usually reserved for cutting power in "abnormal" situations; were it's not too inconvenient if the power doesn't automatically coming back on once other conditions are satisfied.
Again, look into wiring circuit through the "normally closed" (N.C.) contacts of a regular relay, where the coil only gets energized, opening the contacts from the momentary load shed signal.
You will then need wiring, and a normally open (N.O.) contact on the same relay to "latch" the coil. (This uses a normally open (N.O.) contact of the relay (that closes when relay is energized) so that relay stays energized when the initial momentary load shed contact opens. Basically the relay's normally open (N.O.) contact is wired in parallel with the load shed signal's contact to the coil.) You then need a manual "Reset" pushbutton (normally closed) wired in series with this N.O. contact, ahead of the coil, that opens to "unlatch" (de-energize) the coil (and all contacts go back to their normal (coil is de-energized) status.
^Hard to describe in words, put REALLY simple if diagramed. I'll try to find an example.
Thanks. I have designed circuits for many years, so I am not unfamiliar.
Other areas of my load shed system will use GE RR9 relays.
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
2-34x15 Tractor Rims (A50775)
2-34x15 Tractor...
Galvanized steel fence (A55758)
Galvanized steel...
2016 BOBCAT S770 SKID STEER (A52705)
2016 BOBCAT S770...
Unused Delta Crash...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
