Solid State Relays SSRs, anybody use them for HEAVY Loads?
   / Solid State Relays SSRs, anybody use them for HEAVY Loads?
It's a pain with those heavy wires to remove them from the breaker and bypass it.
Curious how a Hot tub CGFI with the neutral works.
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #12
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #13
I use LoadSheddingControllers load shedding products. They might work for your needs. Very reliable products....up to 100 amps.
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #14
My neighbor leaves a valve open (that I added to ameliorate leak-downs) and main switch 'on' for his 6 hp 80 gal 2-stage compressor. It'll cycle every 40 min or so for a whole weekend, and he just ignores it. (out of sight out of mind). Small wonder he has to re-tighten the compressor's head bolts 2-3 times/yr. (no torque spec or pattern needed to do that 'good enough' .. :rolleyes:)
How many times do I imagine that WGB just needs a timer-switch? IMO it rarely takes half an hour to forget to turn off something that's rarely used and sucks power when ignored.
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #15
I like that idea of tripping out the GFI with the Load shedding signal. Easy to do.
Amazing how much leakage current the CGFI needs to trip. Tried 1 meg, nope, 470K nope, then did some googling and calculating. Was amazed I had to go down to 2.2K. And that is how I will shut off the hot tub for load shedding, provided I don't have more nuisance tripping.
Wait, what?
You're going to use a relay to short line to ground (or neutral) to trip out the GFI as part of a load shedding scheme?
Maybe on second reading you're "shorting" through a 2.2k ohm resistor? Is that line to line or line to ground?
Something just seems inherently sketchy about "shorting a GFCI to be a relay" that, although that's sort of what the "Test" feature on a GFCI does.
If line (120V) to ground through a 2.2kOhm resistor, isn't that like 54 milliamps to ground? This seems like a lot given that GFCI's should trip out in the 3-5mA range, but a GFEP (Ground Fault Equipment Protector) trips out in the 30mA range, so you may be on target if you have a GFEP instead of a GFCI.
On my hot tub, the local disconnect switch (as required by code) is a GFCI (or GFEP?) breaker in a fiberglass enclosure, that's feed from a standard type 2 pole breaker in the panel-board.
If I wanted to load shed, I would simply change out the breaker in my panel-board with a shunt-trip breaker that triggers off the load shed signal. This eliminates any relay, but requires a manual reset to turn back on. Requires a space "space" next to the 2 pole breaker in the panel-board for the shunt coil attachment.
BTW: What's so bad about having a coil energized?
Thanks. I have so many projects on my plate and can't afford to just go out and buy a load shedding system. The security RF equipment I am using has really impressed me, although I am not a fan of wireless, for the most part junk.
I do believe you are correct Coby, I got a zero in the wrong place. I admit, it doesn't conform to any accepted manner of doing things, but I actually see little difference in shutting the hot tob off with that breaker, or pressing the test button which is easier and makes for a periodic test, OR tripping it out with a relay. It is actually a really good test as well.
As far as not having a coil running. I have so many systems and buildings, I am conscious of the accumulated 24/7 consumption, all these systems represent. People on here have scoffed at that. but to each his own I guess. I feel sick, if I realize I have left the lights burning in the barn overnight, or some such thing.
What is a shunt type breaker? My HT is about fifty feet from the house Fed from a panel in the wood shed with a FP CGFI. I guess the twistlock at the hot tub counts as a local disconnect.
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #17
It's a breaker with a "shunt trip" coil on it that opens the breaker when coil gets a signal to do so.
It's a one-way operation. You have to manually reset the breaker.
From what I see, the coil module that's added to the side of the breaker occupies a space in the panel that another single pole breaker would otherwise use. (So a 2 pole shunt trip breaker would occupy the SPACE of 3 poles)
Thanks. I am going to my surplus electrical dealer any day so I will put that on my list.
I knew I had seen one. A friend is in the elect dist bus and I am always getting weird stuff when they do inventory and throw stuff out.
It's a square D, DIN RAIL, 15 amp unit but I can't figure it out or what is written on it. It says SHUNT TRIP, but seems like it's just an AUX or pilot type contact. I know it's too small, but I'm curious about them now.
   / Solid State Relays SSRs, anybody use them for HEAVY Loads? #19
....or just wire circuit through the ‘normally closed’ contact of a regular electro-mechanical relay, and coil only energizes from the load shed signal and contact opens.
Normally coil will be unenergized and circuit continuous.
I looked at that shunt breaker. Yes, it does a you say. What would that normally be used for?. Very ambiguous wording on the unit.
The load shed signal is only momentary. A VERY small miniature relay.
2010 Toyota Prius Hybrid Hatchback (A55758)
2010 Toyota Prius...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
UNUSED WOLVERINE PFF2-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
1989 WELLCRAFT 17 SPORT BOAT (A54756)
1989 WELLCRAFT 17...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
